smg owners
Old Dec 3, 2004 | 04:47 PM
  #21
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by alpineweiss' date='Dec 3 2004, 07:23 PM
Usually N + ebrake, sometimes in gear + ebrake. My car sometimes jerks when the engine is shut down in gear
[snapback]64280[/snapback]
Never had the car jerk on shutdown. Are you setting the brake?
On a relatied but different note, if you leave the car in gear with the parking brake on while the engine is running and get out of the car, it'll shift back to neutral after a short time...
Old Dec 3, 2004 | 05:47 PM
  #22
PabloR's Avatar
I too have the problem while the Idriv is initializing that the car has trouble recognizing shift changes. Once in a while it gets stuck in 1 or R and will not switch to N, regardless of what the shifter is doing. Sometimes it gets stuck in N too. Is this a software glitch? I have 11.x
Pablo
Old Dec 3, 2004 | 05:59 PM
  #23
JDN's Avatar
JDN
I don't think that has anything to do with software, PabloR. Mine does that on occasion. I just slap it around and a couple of times and it catches up. I ran 11.3 a long time and now I think I have 14.3. That particular quirk hasn't changed. I feel sure it's something we are doing unless others have experienced it, too.
Old Dec 3, 2004 | 06:31 PM
  #24
CRRobert's Avatar
I have had some issues when initializing also, the light at the SMG lever is in R or 1, but display says N.
Old Dec 3, 2004 | 08:22 PM
  #25
alpineweiss's Avatar
My Ride: 09 E90 M3
Originally Posted by Rudy' date='Dec 3 2004, 09:47 PM
[quote name='alpineweiss' date='Dec 3 2004, 07:23 PM']Usually N + ebrake, sometimes in gear + ebrake. My car sometimes jerks when the engine is shut down in gear
[/quote]
Definately not the ebrake. Feeling can compare to a noob driving stick and engaging the clutch too quickly and stalls the engine It's only happened a few times though, so not really concerned.
Shifting from R/1 -> N prior to starting seems to be no problem if I'm on the brakes the whole time. Otherwise it's sloooow.
Old Dec 3, 2004 | 08:33 PM
  #26
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
[snapback]64395[/snapback]
So you're saying the car jerks even though you've set the ebrake? (I figured that's what you meant by the car jerking but since I always set the brake before turning off the car and since it's never happened to me, I was thinking that if you set the brake first, you wouldn't have that problem.)
Old Dec 4, 2004 | 12:47 PM
  #27
realtyman's Avatar
My Ride: Now Driving a Freakin' Prius! Was... 2004 545i | SMG | White/Black | Sport | NAV | Logic 7 | PDC | Fold-down Seats | Adaptive Headlights | Cold Weather Pkg | Clear-again Bra | Mud Flaps | Bluetooth | Coat Hangar | Aux Input | All Weather Mats | 18"X8.5" BBS RK w/ Michelin Pilot Alpin's (winter) | New steering rack @ 1.2K & 17K miles| Software V.19.1 | B&B Exhaust (vrrrroooooommm!) <---Click.
Pablo
[snapback]64357[/snapback]
Same here. I find that sometime I need to turn the key back to the 0 position put it in N (sometimes need to put it in D then N).
Eventually I get it.
Old Dec 4, 2004 | 01:14 PM
  #28
My Ride: 09 E90 M3
Originally Posted by Rudy' date='Dec 4 2004, 01:33 AM
[quote name='alpineweiss' date='Dec 4 2004, 12:22 AM']Definately not the ebrake. Feeling can compare to a noob driving stick and engaging the clutch too quickly and stalls the engine It's only happened a few times though, so not really concerned.
[snapback]64399[/snapback]
[/quote]
I leave the car in first, set the ebrake, the car rolls back a little, and then when I shut off the engine it would jerk forward. I keep my foot on the brake now shutting it off...seems to prevent any chances of it happening.
Old Dec 4, 2004 | 06:43 PM
  #29
JDN's Avatar
JDN
Originally Posted by realtyman' date='Dec 4 2004, 03:47 PM
[quote name='PabloR' date='Dec 3 2004, 09:47 PM']I too have the problem while the Idriv is initializing that the car has trouble recognizing shift changes. Once in a while it gets stuck in 1 or R and will not switch to N, regardless of what the shifter is doing. Sometimes it gets stuck in N too. Is this a software glitch? I have 11.x
Pablo
[snapback]64667[/snapback]
[/quote]
I think the best solution is to ignore the display. Slap the stick where it is supposed to be and go ahead. Worked on starting this morning. Don't wait for the display which can be slow to respond. Just slap the stick to N and crank away. Same thing on moving to R or 1st.
Old Dec 4, 2004 | 08:26 PM
  #30
PabloR's Avatar
Originally Posted by JDN' date='Dec 4 2004, 11:43 PM
[quote name='realtyman' date='Dec 4 2004, 03:47 PM'][quote name='PabloR' date='Dec 3 2004, 09:47 PM']I too have the problem while the Idriv is initializing that the car has trouble recognizing shift changes. Once in a while it gets stuck in 1 or R and will not switch to N, regardless of what the shifter is doing. Sometimes it gets stuck in N too. Is this a software glitch? I have 11.x
Pablo
[/quote]
[snapback]64826[/snapback]
[/quote]
In my experience, unless the display shows the right gear, the car wont go... I was stuck at a stoplight for 30 secs the other day after switching to N. It would not go back into 1...
P
