SMG
Is it necessary to utilize sixth gear while driving under 75mph other than to lower the rpm thereby saving fuel. I guess im asking how many members with SMG actually get up to 6th gear?
My Ride: G30 M550i
Model Year: 2018
What engine? On my old 545, I used 6th gear fairly often (under 75mph). The V8 had plenty of torque to allow use of 6th in areas where the speeds were much lower...
My Ride: 2006 550i SMG
I short shift a lot I guess out of habbit trying to save fuel and always end up in 6th. I do notice that in "D" mode, the computer stays in 5th longer.
My Ride: G30 M550i
Model Year: 2018
Originally Posted by rayray06' post='505450' date='Dec 11 2007, 09:12 AM
2006 530i/sport
You just have to treat each situation individually and decide what works and what doesn't...
Why don't use the 6th if the conditions don't need fast accelerations ?
Less noise, less gas to use .
BTW you can set the SMG in Drive mode (without sport, otherwise it will remain in D5) and travel at 75 mph peacefully, assisted by the kickdown in case of emergency .
Mihainede85
03-26-2023 07:49 PM
