A small but useful E60 trunk tip...
My Ride: G30 M550i
Model Year: 2018
If you're like me, you have a ton of stuff in your trunk. My job requires me to have things like a tool box and a briefcase with me most of the time so naturally, the trunk is where I keep them.
On my E39's, this stuff was constantly getting tossed around, flipped, slammed into the back, slammed into the front, etc. The little rubber straps on that car really didn't do much good and I wasn't about to tie them down or use any cargo nets, etc. since I was always needing to take them in and out. (I did tie down large bulky objects pretty often -- those tie downs are handy.)
On the E60, the large trunk mat is reversible. One side is the fuzzy carpet (that male velcro sticks to quite well) and the other side is a rubberized surface that prevents things from sliding around much better than the carpet.
A simple solution to an old problem!
Rudy: Does the trunk 'mat' come right out, or is there any point where it needs to be unhooked from something. Or is it as simple as 'lift up and pull straight out' then 'turn over and lay be down on the floor?
Thanks much,
Sam
Thanks much,
Sam
Simply pulling it out seems feasible.
How about the circular storage compartment one gets when having run-flats? It seems ideal to avoid things from shocking around in the trunk - fitting for tools, shopping bags and whatnot.
-paasan
-paasan
My Ride: G30 M550i
Model Year: 2018
Actually, even if you get run-flats, you get a doughnut spare in the well.
I thought about removing it for extra storage but I remember many years ago reading about why BMW and M-B design their cars with horizontal spares located under the trunk mat.
Supposedly, the tire location improves safety in a rear-impacts. Based on that alone, I'm going to leave my spare there.
Our car has the storage compartment.
However, our studded winter tyres don't come as run-flats AFAIK, so we put in the space saver wheel during winter. Replacing the wheel and jack with the "cardboard" storage compartment is a simple operation.
-paasan
-paasan
James: Aren't you concerned about modifying the weight distribution characteristics of the car? I would think it would have a handling impact and would definitely affect how the car handles in an emergency avoidance situation; not sure though. Thanks.
Sam
Sam
My Ride: G30 M550i
Model Year: 2018
Originally Posted by jksanford' date='May 24 2004, 11:09 AM
Rudy,
Do you know what option got you the storage compartment? I've seen it in a couple of pictures, but my 530 doesn't have it.
thanks,
james
thanks,
james
Also, sj3 brings up a point I forgot about in my earlier post. There seems to be more reasons to leave the spare than to remove it.
