Silly Dashboard Setting Problem
Old Dec 8, 2025 | 02:06 PM
ZeroDfx's Avatar
My Ride: 2008 550i 6-spd; 2007 530i Sport
Default Silly Dashboard Setting Problem
I stupidly left my parking lights on overnight and managed to drain the battery. I recharged the battery to full voltage and was alerted that I needed to reset the time/date which I did.
I noticed that my mileage and MPG readings had reset automatically to kilometers, so I went back into my display menu and indicated my preference for Miles, PSI, MPG, & Fahrenheit temperature readings.
However my instrument cluster readings are not switching. Any idea what I need to do to get my US readings back again? FWIW, I did the reset with the car idling in neutral if that matters.
Thanks
Old Dec 8, 2025 | 04:32 PM
donpb's Avatar
My Ride: '06 530i N52
What codes are you seeing?
Old Dec 8, 2025 | 04:46 PM
ZeroDfx's Avatar
No codes....it's just the instrument cluster readings telling me mileage, MPH, MPG, etc. I want those displayed in miles (not kilometers), miles per hour (not km per hour), and MPG (not KM per gallon).
It should be a simple Display Setting choice; but it didn't switch over when I selected it in iDrive.
Old Dec 8, 2025 | 05:00 PM
donpb's Avatar
The reason I asked if you read any codes (BMW-specific) is because sometimes things won't set unless some code is cleared. Often times whenever the battery discharges, there can be a Christmas tree of codes.
Old Dec 8, 2025 | 06:42 PM
ZeroDfx's Avatar
Oh, OK...I'll run Carly in the morning and see if anything pops up; if so, I'll clear them and see what happens. Thanks for the suggestion. Will let you know what happens.
Old Dec 11, 2025 | 08:41 AM
ZeroDfx's Avatar
Looks like the car accepted my display preferences in iDrive. The next time I went out and started it up, all my requested preferences were showing on the instrument cluster.
It may just be that the changes weren't being displayed simultaneously as I was making them with the car running. Glad they finally showed up.
Mzmkont
Dec 13, 2025 05:49 AM
Shirex
Jan 23, 2025 04:18 PM
BMW565
Nov 6, 2017 06:03 PM
Transporter
May 2, 2009 04:25 AM
pa550
Jan 7, 2007 05:45 AM
