Should I get this e60?
My Ride: 2008 BMW 535xi
^^^^ Have you priced injectors? Because they're NOT cheap, and, honestly, not that easy to swap out without the proper tool and consumable parts.
FWIW, I went into my n54 ice cold- I'd never owned a BMW before, but I was super handy, with a garage full of tools, access to a machine shop and oscilloscopes at work, and a second car to drive so I would never have to fight with my car just to get to work in the morning... I'm not saying no, but be prepared for this thing to live rent free in your head while you try and get it sorted or stack the chips to buy parts. I've had my wagon for a year and a half now, and have put on maybe 25k miles in that time, but it's been a LOT. I love the car, and I love working on cars, so it hasn't been that bad, but working on these cars is a way different experience than your lancer. To give you a sense- I bought a dedicated laptop to run INPA and ISTA for this car, and have bookmarked both newtis.info and realOEM. Oil changes are super easy, so are plugs other than the specialty ($10) socket you need to change them, but they're honestly the tip of the iceberg.
I'd keep looking to be honest. Three owners in a little more than 2 years. 5 owners total, the last had it for only 2500 miles...
There are a lot of red flags there.
Though, if you're handy and planning to do the work yourself, you're close enough to FCPEuro to drive there and save on shipping.
My Ride: 2x E61, 1x E60, 1x E90
Model Year: 07,07,10
Engine: N52, N54
That is a little steep for a car with misfires. I would talk the price a little more. AWD N54 cars are a little harder to work on due to 2 turbos/awd up front. I would pass unless it was $1500.
Probation Members
My Ride: 08 535I Sport
I own a 08 535I and my son has an 08 535XI and they don’t say anything about Twin turbo on the engine covers etc. I’ve been working on them both myself and Installed a new water pump in/out hoses thermostat and antifreeze in mine and that got me right up there with the turbo on the outlet side of the pump. Is there another turbo down stream?? And still the drivers side dual tip exhaust ‘cluster’ , I’ve never seen engineering like this in my life .
( also on another note ) the car fax noted that the valve cover gasket was changed and then two months later the valve cover itself was changed 🥴 that’s telling me that there may be some inexperience at the shop 😅. I just made the same mistake on my sons car and apparently the valve covers warp so it’s best to replace cover and gasket at the same time , especially because of the integrated PCV valve etc in the cover. In any case it’s good that you love the car because that makes everything easier . All the best ...
My Ride: E61 530xi 6MT
Engine: N52
Is this car actually a single turbo or twin ?
Engine: N52, N54
2 snails:
![](https://cimg1.ibsrv.net/gimg/5series.net-vbulletin/640x480/44950890d84e172f987b7ed6ec002c0b_5e9769eaf67bfefa149e83863c1233deb77932f5.jpg)
My Ride: 2006 E61 530xi - Premium, Cold Weather Package
Engine: N52
I'd concur that multiple owners in a couple of years is a big red flag. On the other hand, I've bought virtually all my most-interesting cars from previous owners who got overwhelmed by some aspect of maintenance. So the previous owners' f-ups are not necessarily showstoppers, at least in my view...
From your perspective, however: These are not beginner's cars. Your eagerness is a help, but you'll have to back that up with a significant investment in tools, pretty shortly. At least a set of Star (Torx) drivers and sockets to start...
Always work hard to gather all maintenance records...
But maintenance records, even when you have 'em, aren't necessarily what they appear to be:
To further complicate your decision algorithm: I wanted to replace my head gasket to address what seemed to be relatively minor oil leaks. Turned out that a previous worker - a 'professional' shop! - had sheared off a couple of head cover bolts in the replacement, then left the sheared heads in place. Remember that most bolts on these engines are aluminum; use once, then discard.
My life with this car started with replacement of all coolant hoses. Again, previous worker had cracked or snapped various hose nozzles, connectors, guides... Well, you'll see.
On misfires: I can say that the couple I've had were addressed with an overdue replacement of all spark plugs; nothing more profound.
We are all gonna be eager to see your decision on this bad boy!
My Ride: 2009 535i Auto Sport Pkg
Sounds like the previous owner tried to fix the misfires and couldn't. I would definitely have that diagnosed in the PPI. That mileage is when a lot of stuff will start to fail. Replace all the coolant hoses, high pressure fuel pump could start failing at any moment. If 2 injectors have been replaced, the rest could soon follow $$$. Should do a fluid/filter change on the trans soon. Check the control arm bushings. Like others have said, be prepared to spend a couple hundred a month in the first year to get it in good running order. Water pumps can fail or start leaking at any mileage. All that said, its a pretty cool car. Good luck!
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
I didn't read through all the posts but ill put my 2 cents in. If you have an 08 that has an MSD80, then you're not going to fix the issue by changing injectors. Remove your DME and have your MOSFETs replaced. I believe the effected 535xi productions were from 04/08-08/08. I could be wrong(30BA, 30B
if you have one bank down replace all six and get it over with. Find out if you have those codes and of so that's your issue
![Cool](https://5series.net/forums/images/smilies/imported/cool.gif)
