Shell M1375.4
My Ride: E60 530i
Engine: M54
Just found the Shell M1375.4 ATF from LandRover dealer - $32.45 + tax per quart. Dealer is located in 2144 Washington St. Hanover, MA 02339. Definitely not cheap !!! A typical drain/refill for my 530i would need about 5 quarts ==> $162.25 + tax.
Ching-Ho Cheng
Ching-Ho Cheng
I've decided I want to change my atf in my '06 550 since it has 70k miles. I emailed Ken at Bavauto, and he is telling me only Shell M1375.4 will work in my transmission and it is only avail at the dealer and costs $570. Granted the size the container is good for several changes, I don't need/ want to store extra ATF for an unlimited period of time.
Is there not a comparable ATF on the market? For the people that keep their cars long term, what are you using?
Pentosin Transmission Fluid
As someone else already mentioned, a really good place to get the fluid and filter/pan kit is RM European.
My Ride: 2006 BMW 550i
My Ride: x3 2.0 d - 2008
http://www.championlubes.com/TDS/tds...4105142_lr.pdf
CHAMPION OEM SPECIFIC ATF M-1375.4 PRODUCT CODE: 3012
I recently bought a case (12 qts) of Shell 134 ATF for $66 from GH Berlin Oil Co. in Manchester, NH.
Shell 134 is for my MB C280.
I will call them and find out if they sell M1375.4 spec ATF.
My Ride: 2015 535D M Sport
Everything you need, you can get here: The CTSC - ZF Parts
Use ZF parts and approved fluid.
Here is the V8 change kit: http://www.thectsc.com/products/oil-...ce-186-50.html
Here is the 6cyl change kit: http://www.thectsc.com/products/oil-...ai-187-43.html
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
