Several Error Codes After Panic Alarm Please Help!
Okay, I will be the first to admit that I have no clue what I’m doing. I bought a 2007 BMW 530i a couple weeks ago and I’m still very new to the car. I had zero issues driving it today, and after I engaged the panic alarm using the key fob (just trying to figure out how it works) I put the fob in the ignition, and I now have every malfunction you can think of. ABS malfunction, transmission malfunction, dynamic drive malfunction, steering wheel lock, passenger restraint system malfunction, and the car will not start. Please tell me this is just a little glitch with an easy fix. This is the only car I have and I’m at a loss.
Unplug the negative cable for 15 mins that should get you going or if you have a charger charge the battery once you reconnect it. I would take the battery to Advance Auto or anther store and have it tested. The battery might be on its last leg.
(Post 1604721)
https://cimg8.ibsrv.net/gimg/5series...629829916.jpeg |
