Service issues
Old Jun 20, 2005 | 11:29 PM
spinedoc's Avatar
My Ride: 545i Titanium gray poplar l Sports package l Logic 7 l PDC NAV l sunshades l chromed 124's l ski bag l euro tint
Hope someone can help me with some questions.
1. Had a problem with rough running engine in Phoenix (110 degrees), seems to have stopped but as bad as it was I wonder if it should be checked.
2. Does everyone use premium (91) octane gas in their 545?
3. If I havent had a software upgrade in a while (6 months) should I call and ask for one? Is curent software a reasonable service request? It seems like there may be problems with the parking LED's after the upgrade?
4. I have problems with my passenger side window about 50% of the time activating the anti-trap. Is this software or window motor?
5. My service rep tells me that I cannot get AUX input added for my IPOD. If I have this done aftermarket will I screw up my warranty?
Thanks
Old Jun 21, 2005 | 06:32 AM
stream's Avatar
Banned
Here's my answers:
1) never gets that hot here!
2) yes
3) don't think they'll upgrade just for asking, and I just got 17.01 and all my lights work
4) they replaced my front passenger window drive and it's fixed--now the drivers window is acting up...
5) I had aux input installed 2 weeks ago--why did they say you can't get it installed? I don't think there's a way to do it aftermarket (at a reasonable cost) with the MOST bus
Old Jun 21, 2005 | 07:17 AM
swajames's Avatar
I had a rough running issue and they adjusted the valve clearance quoting a service bulletin (you'll probably find it with a search here, or I can post the bulletin number when I get home tonight). It's better, but not *totally* eliminated. One other thing is that my SA was saying that the rough idle/running issue is much more prevalent in states like CA that have crappy gas, he said that BMW have told them that they see the rough idle issues primarily over on the west coast. I see you're in AZ, no idea if you can get better than 91 octane there but if you can it's worth a try. My SA also implied that using an octane booster could help with the gas issues. Anyone done that? If so, did it make an appreciable difference?
Old Jun 21, 2005 | 07:23 AM
subterFUSE's Avatar
Never had rough engine.
I use premium gas (93 octane)
I am getting service soon, and will demand a free software upgrade to fix the following:
Radio always turns on when car starts
Bluetooth 30 second outgoing call limit
iDrive restarts itself occassionally
iDrive doesn't always turn off when I turn off car, runs down battery
My passenger window antitrap gets tripped almost everytime I roll it down. I will have them fix that.
My sunroof also makes a terrible banging noise when I close it after using the vent feature. Its very startling.
Old Jun 21, 2005 | 07:28 AM
Edlee's Avatar
Mine is a 545i and my friend's is a 520i with a 2.2 li engine.
It gets rather hot here in Singapore at times and we have both experienced rough idling and hesitation when it gets really hot here (approx 36 degrees C) We use 98 octane petrol.
As for your window, I suggest getting it checked. I had a problem with my driver's side window. Everytime I use the remote to unwind and wind my windows, the driver's side will stay halfway refusing to budge. The dealer here changed the motor and all has been fine ever since. Regards the anti-trap, just try wiping your window clean and it should work fine. Otherwise it could be the sensors that are dirty and this requires action by your dealer.
I got my ride upgraded to 16.2 about a month or so back. My lights still work fine. However, I have heard that some of our locals are having problems with the "eyebrows" not working after the ver 17 software.
I personally do not think I will ever need the ipod in my ride, but a few guys here in Singapore have had that done by the local agent here. They're pretty happy with it. Tell your dealer the guys as far away as SIngapore can get this done thru their BMW dealer ant there is no reason why they can't do it for you; especially so as I-Pod is American. Get them to check with BMW on how to do it.
Old Jun 21, 2005 | 07:31 AM
Edlee's Avatar
Originally Posted by swajames' date='Jun 21 2005, 09:17 AM
I had a rough running issue and they adjusted the valve clearance quoting a service bulletin (you'll probably find it with a search here, or I? can post the bulletin number when I get home tonight).? It's better, but not *totally* eliminated.? One other thing is that my SA was saying that the rough idle/running issue is much more prevalent in states like CA that have crappy gas, he said that BMW have told them that they see the rough idle issues primarily over on the west coast.? I see you're in AZ, no idea if you can get better than 91 octane there but if you can it's worth a try.? My SA also implied that using an octane booster could help with the gas issues.? Anyone done that?? If so, did it make an appreciable difference?
[snapback]141556[/snapback]
I also had my valve clearance done just last Friday. Seems to have improved on the rough idling. However, I have noticed that during bad traffic situations where it takes you half an hour to travel 3 Km, the tachometer gets jumpy - needle jumps about 100 to 200 rpm - but the ride is not affected.
Old Jun 21, 2005 | 08:14 AM
teriyaki88's Avatar
My Ride: 2004 BMW 545i, Olivin Green, w/Sports Package, basic stereo, chrome wheels, tinted windows, Bluetooth enabled with Moto V710 (Verizon), Sirius Sat Radio (aftermarket), Auxiliary Input for Ipod.
Thanks
[snapback]141453[/snapback]
1,3,4: I had the anti window trap warning megs, they fixed it will a software upgrade. No problem since then.
5: Don't tell them its the Ipod Aux. I'm sure they misinterpreted thinking you're asking for IPOD integration via IDrive. Just tell them you want the AUX for other audio sources (ie portable DVD player, laptop, PSP, portable CD, etc)
And it does not void your warranty. The work is performed by BMW tech and not by outside vendors.
Teriyaki
Old Jun 21, 2005 | 04:49 PM
cobradav's Avatar
Thanks
1. My rough idle was (and still is but better) only within the first 60 seconds. At first indication it dropped to 450 RPM and almost died but recovered. Software update to 16.2 helped quite a bit. Dealer submitted PuMA case and they came back with more software. I am going to hold off for awhile. But it is in a service bulletin as mentioned elsewhere. Some really bad cases are attributed to hardware with hard to get parts and dealer must submit a PuMA case to be eligible to get the parts. Do a search and you should find both bulletins.
2. I use 93 octane (Florida) in same engine as yours.
3. Software may fix #1 and #4 so free. You could also claim iDrive screen blanking if u needed more ammo.
4. Anti trap is usually software. This and your engine problem ought to get you number 3. If software does not fix then u (and dealer) should know its hardware.
5. As mentioned by other members do not tie Ipod to Aux Input. It is generic to all audio sources. I use cassette taoe and MP3 Player. Only BMW part. Do another search - go to mod forum for this search - Find bulletin and list of dealers, though I do not remember Arizona in the list. But that is non essential - Print list and hand to dealer - it is quite common - at least for us E60.netters.
And Welcome to the forum and mighty fine ride u got
Old Jun 21, 2005 | 05:06 PM
EBMCS03's Avatar
Silly question! MINIMUM 91!!
Old Jun 21, 2005 | 07:58 PM
pennetta's Avatar
Thanks
Answer:
1. I had a rough idle, they raised the idle speed. Its better but not gone.
2. Always
3. Software sometimes fixes things but sometimes renders other things inoperable. Not all of the E60's have the same hardware so the softwares effects can be different from car to car. If nothing is wrong, might not be worth the risk to update the software.
