Service center customizable preferences
My Ride: 2004 545i [01/04 build]
Titanium Gray Metallic II / Black leather / Poplar Woodgrain / Style 124 Wheels
6SP Manual
SP/CWP/PMP/L7
Bluetooth retrofit
I understand that vehicle preferences can be set at the service center, but what options are available? For instance, is it a flip of a switch for them to enable daytime running lights, just like they can do with bluetooth?
How far does it go? Can it be setup to increase the feeling of weight on the steering wheel while turning? Or how aggressively the active suspension reacts?
My car is 01/04 build 545i with manual transmission, non-nav, with premium/cold/sport/premium sound packages.
Thanks!
-Jason
Thanks!
-Jason
6SP Manual
SP/CWP/PMP/L7
Bluetooth retrofit
Thanks!
-Jason
Thanks!
-Jason
My service advisor is supposed to call back after he has spoken with a technician to let me know what all is customizable.
Ones I know of
1. Adjust sensitivity of auto headlights
2. Program mirrors to fold/unflod on key lock/unlock.
3. Allow boot to open only after unlock.
6SP Manual
SP/CWP/PMP/L7
Bluetooth retrofit
My Ride: E90 M3
Model Year: 2011
Originally Posted by Jason' post='421830' date='May 7 2007, 09:38 AM
Do all models do the fold/unfold of the mirrors, or is that an option? My car is an 01/04 production model.
My Ride: 2001 BMW330ci, Steel Gray, Black leather, Steptronic, PP, SP, PDC, Heated seats, Xenon head lights, HK, 6 disk changer, OEM alarm, OEM clears,Iice white fog lights ,Universal trasnciver, 17 inch Michelin Pilot Sport Tires
2005 530i Titanium Gray,Black leather, Nav.,HUD,PP,CWP,SP,PDC,Xenon lights,Steptronic,Logic 7 sound system,,Fold down read seats,Power shades
ON ORDER
Originally Posted by bruce_miranda' post='421196' date='May 4 2007, 06:35 PM
Ones I know of
cheers
vern
DTRL is has been an iDrive set-up option for over a year now, thats the reason I didn't mention it.
6SP Manual
SP/CWP/PMP/L7
Bluetooth retrofit
The dealer faxed me a print out from screen shots of the update system with the available options for my 01/04 build 545i.
Anti-theft system
Anti-theft system
- Interior sensor
- active [default]
- not active
- Tilt sensor
- active [default]
- not active
- Arming/disarming
- Disarming only with remote control
- Lock and remote control [default]
- Open tailgate
- if double -unlocked
- always [default]
- 1-touch funct, open driver window
- active [default]
- not active
- 1-touch funct., close driver window
- active [default]
- not active
- 1-touch funct., open passenger window
- active [default]
- not active
- 1-touch funct., close passenger window
- active [default]
- not active
- 1-touch funct., open rear window
- active [default]
- not active
- 1-touch funct., close rear window
- active [default]
- not active
- Convenient opening, remote control
- active [default]
- not active
- Exterior lights
- Daytime running light US
- active
- not active [default]
- Automatice driving lights control (set of threshhold values)
- normal
- sensitive [default]
- very sensitive
- Fan
- Fan correction
- Increase
- Decrease
- Fan correction
- Vents
- Flaps set point value correct
- +3 degrees
- +2 degrees
- +1 degree
- -1 degree
- -2 degrees
- -3 degrees
- Recirculated air memory
- active [default]
- not active
- Off memory
- active
- A/C off with AUTO
- active
Jason, in asking a question you've provided the most comprehensive answer to the forum I've ever see. Well done.
