Service Bulletin to relocate MPM
My Ride: 545i
Looking for the service bulletin to relocate the MPM in the trunk. Figured I should move it in case I get any leaks. Found a couple links to the SB but they were dead.
My Ride: 2006 BMW 530xi 6MT
Engine: N52
You need these two pieces:
SI B 61 13 06 electrical problems caused by water ingress.pdf
B611306Attachment.pdf
My Ride: 545i
Thanks. Is there one for relocating the MPM though? The SIB only shows relocating the MULF and PDC modules. I know I could put it anywhere but I would prefer to do it as per BMW instructions.
My Ride: 545i
The one you posted was the one I was referring to. Just wondering if there was any other instructions to relocate the MPM. Its another module in the same location, I just want to fasten it where BMW suggests.
Engine: N52
Honestly hadn't noticed that it doesn't mention MPM. I downloaded the SIB a couple years ago and have never gotten around to it. I imagine the same procedure can be done to relocate it. Please post if you do it and where you put the MPM.
I asked my service advisor about this a few months ago before my car went out of original factory warranty. He couldn't find anything like these SIBs. Or, maybe because I had not experienced any leakage or water in my trunk, he believed this SIB was not applicable.
Just so I understand this correctly, the dealer will only perform this work if you complain of a leak, or water in the trunk, correct? They will not do this work just because you request it, if there is no complaint or evidence of any water leakage problems?
My car is 2008 528i which is still covered by the CPO warranty until July of 2014.
Thanks for any clarifications about getting this done by the dealer.
