Serious Malfunction?
Originally Posted by ImolaRedM' post='252148' date='Mar 9 2006, 09:40 AM
That was my initial thought too but a bad ABS sensor (or misaligned sensor) would also give an ABS fault. Sounds like that's not the case. So my "guess" is that it has more to do with the ECU that controls traction. In other words... it looks like it's more up stream from the ABS sensors. I wouldn't be too worried but get it checked out.
It's not a serious malfunction and they are easy to replce.
Service will find the broken senson in no time,
the cars computers register and locate the problem.
Originally Posted by 5 Rakete' post='252154' date='Mar 9 2006, 01:05 PM
He mentioned the orange brake light which could be a reflection of a corresponding ABS fault.
Ah... I missed that. In that case I would agree (not that my opion matters )
Originally Posted by Ricracing' post='252156' date='Mar 9 2006, 01:08 PM
The sensors seem to give BMW drivers the most problems.
My Ride: 2006 BMW 550i
Ok, so I dropped the car in the morning. The SA called sometime ago, and told me that there is a SENSOR in the STEERING COLUMN which is MALFUNCTIONING. He said that he doesn't remember the name of the sensor right now, but it is because of that part all these WEIRD messages are coming.
I asked him about brakes, and he said, that The comfort stop cannot determine the position of the steering, therefore it is grabbing at the DISC BRAKES as well.
Therefore replacing that one sensor will fix all my issues. He also said that the shop may also perform a software upgrade. So my car should be done by tomorrow evening.
Fingers crossed, let's see what happens. I will know tomorrow for sure about the work performed. I will post an update.
Finally got my car back yesterday. They said that they changed something in the steering column?. Here is what my receipt states:
1 61-31-9-111-997 SWITCH UNIT, STEERIN
FAULTY SZL MODULE. FOUND FAULTS STORED IN SZL: A85D, 951D. PER SI B 34 04 06, REPLACE SZL. R&R SZL AND PROGRAMMED VEHICLE WITH CIP 20.02. COMPLETED SZL REPLACEMENT IN CIP, CALIBRATED STEERING ANGLE AND CLEARED FCS. RECHKD---ALL OK.
Anyone has any more details to add as to what exactly was done, except for obvious ones. I know that now I have the new CIP, and the SZL is replaced. But what is SZL. What is 61-31-9-111-997 Switch Unit. What is SI B 34 04 06. Also, any ideas, why did this happen?
SI B 34 04 06
Brakes February 2006
Technical Service
SUBJECT
DSC Warning - Various SZL FCs Stored
MODEL
E90/E91 (3 Series), E60/E61 (6 Series), E63/E64 (6 Series)
SITUATION
The DSC warning shows in the Instrument Cluster. An amber "BRAKE" warning may also be displayed.
The following SZL (Steering Column Switch Sensor) fault codes are stored:
5E43 ? LWS (Steering Angle Sensor) internal fault.
94B4 - F-CAN LWS sensor failure
94B5 - F-CAN LWS sensor failure
94B6 - F-CAN LWS sensor failure
or
A85D ? Faulty LWS (E60/E61/E63/E64 only)
CAUSE
Faulty LWS
Contamination of internal optic disk - optic disk material change expected approx. April 2006.
or
Processor programming error (E60/E61/E63/E64 only) ? corrected on parts dated 03.12.05 (Dec 3, 2005).
Note: The part production date is shown on the lower left corner of the barcode label.
CORRECTION
Replace the SZL.
PARTS INFORMATION
Part Number.................Description................ ....Quantity
Refer to EPC................. SZL...............................1
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code Refer to KSD
Labor Operation: Refer to KSD
Labor Allowance: Refer to KSD
Originally Posted by cobradav' post='255971' date='Mar 16 2006, 04:33 PM
This should cover everything
SI B 34 04 06
Technical Service
SUBJECT
MODEL
SITUATION
or
CAUSE
Faulty LWS
or
CORRECTION
Replace the SZL.
PARTS INFORMATION
SI B 34 04 06
Technical Service
SUBJECT
MODEL
SITUATION
or
CAUSE
Faulty LWS
or
CORRECTION
Replace the SZL.
PARTS INFORMATION
Really cool... WOW.. thanks man
My Ride: 2006 530i, Titanium Silver exterior, beige interior, premium package, automatic.
My 2006 530 got the same malfunction today, at only 2200 milles.
When is your production date? Mine is 4th week of Novemeber, 2005.
In recent discussions with my SA he disclosed that this SZL had a pretty high failure rate and was on national back order. Appears to be the same sensor in E90, E60, E63 series at least (I have not validated that via online parts list) but several people were having to drive thru this issue while the parts get ordered and come in.
