Sensitivity of the auto headlights
My Ride: E90 M3
Model Year: 2011
Originally Posted by speedracerF4i' date='Jun 8 2005, 11:08 AM
Repeated cycles is what triggers the light to be on all the time.
My lights would come on inside the garage as I start the car. Once I pull out, the light would go off. Then, I pass through a street full of trees, I notice the green light come on and off about 3 times due to shade/sun light transitions. Finally, the light will be permanently on.?
Depending on your sensitivity setting, make sure that the shadow is dark enough to turn your lights off, in order to make this experiment work.?
I also notice the same pattern with the 7 series.
[snapback]137610[/snapback]
My Ride: 2001 BMW330ci, Steel Gray, Black leather, Steptronic, PP, SP, PDC, Heated seats, Xenon head lights, HK, 6 disk changer, OEM alarm, OEM clears,Iice white fog lights ,Universal trasnciver, 17 inch Michelin Pilot Sport Tires
2005 530i Titanium Gray,Black leather, Nav.,HUD,PP,CWP,SP,PDC,Xenon lights,Steptronic,Logic 7 sound system,,Fold down read seats,Power shades
ON ORDER
Originally Posted by subterFUSE' date='Jun 8 2005, 08:27 AM
Actually....? the headlights were not sensitive enough.
The sensor is a light sensor....? so more sensitive makes the headlights remain off in brighter ambient light.
Even if the dealer adjusts your sensitivity to the highest setting, the lights still come on in broad daylight.
[snapback]137510[/snapback]
cheers
vern
My Ride: On Order:
2006 525i
Alpine White
Auburn Interior
Premium Pkg
Sport Pkg
Cold Weather Pkg
Xenons
Sunshades
Sat Radio
Navigation
bceverly, do you have the aux input installed?
My Ride: G30 M550i
Model Year: 2018
Originally Posted by speedracerF4i' date='Jun 8 2005, 01:37 PM
I really wish BMW would give us the adaptive function even if we turn on the light manually.
[snapback]137625[/snapback]
My Ride: 2004 Titanium Gray 545i auto, navigation, premium sound/Logic7, cold weather, adaptive Xenon, Lumbar support, split rear seat, PDC.
Originally Posted by bmw525i' date='Jun 8 2005, 01:15 PM
My lights worked well before. But ever since I got the 16.2 upgrade, my lights only come on in the garage or if it gets really dark outside. It seems to me that the lights are more programmed to work on a specific time rather than the light sensitivity. My lights will turn on in the evening, doesn't matter how dark or light it is outide but in the afternoons or morning, they won't come on.?
[snapback]137614[/snapback]
I do not think they are time programmed. They work after CIP16.1 just fine as described by kscarrol. If they are being stubborn at dusk and not coming on, you have two options.
1. Switch them on (turn switch to far right)
2. Shhhh.......turn on fog lights (woe betide yee) This actions overrides the sensor in auto mode and forces the xenons on.
I'm on 16.2 and did notice an improvement in my "auto" function. Now less prone to come on in low light (cloudy but not dark). They come on fine at dusk and go off fine as the sun gets fully over the horizon. No issues here. I suppose my windshield is canted a little more back (more rake) but I am not sure that would have a significant impact on sensor operation.
Originally Posted by Hormazd' date='Jun 9 2005, 01:36 AM
I do not think they are time programmed.? They work after CIP16.1 just fine as described by kscarrol.? If they are being stubborn at dusk and not coming on,? you have two options.
2. Shhhh.......turn on fog lights (woe betide yee)? This actions overrides the sensor in auto mode and forces the xenons on.
[snapback]137839[/snapback]
