Seems like some kind of leak.
My Ride: 540i
Model Year: 2017
Clean it and check the next day to see if you can tell for sure where the leak is.
There is typically an aluminum washer and a copper gasket. Maybe you just need to
tighten the hex bolt or replace the copper gasket if it has been loose for a while.
O ok, soon as I was abt to go grab my tools it started to rain smh, and it will until tomorrow in the NYC are, but thanks. Whats are those parts exactly, like what are their purpose
My Ride: 540i
Model Year: 2017
Where the fitting crimps onto the hose is another suspect connection. Clean it and check for new leakage. That
will help you pinpoint where it's leaking. The bolt going through the fitting is hollow. Don't gorilla tighten
it or you may twist it off!
