Seat Adjustment stuck
Hope someone can help, today I found that the forward/back manual adjustment on the drivers seat in my 2004 530d is stuck. I can pull the handle up but the seat does not move forward or backward. Anyone have any ideas ?
Thanks
Thanks
Thanks
Thanks
Hmm.. Did you check all the fuses? If the seat doesn't work at all (no functions) then it is most likely the fuse, but if it partially works, couldn't be a plug somewhere that is disconnected.
PelicanParts.com
07-24-2015 01:26 PM
