Satellite Prep
Old 11-23-2004 | 05:11 AM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
Originally Posted by Lenk' date='Nov 23 2004, 12:14 AM
Actually I have conducted extensive research and plan on ordering the parts to do my own retrofit tommorrow (I do not have the factory prep). The necessary parts for the wiring should be about $100.
You basically need one fiber optic cable and two antenna cables, the power plug is already present for the phone booster. The system in our car is a network. All you need to do is unplug the fiber optic cable going out of the TCU and going to the CD changer. The you connect the fiber optic cable that is purchased from the TCU to the Sirius unit. The fiber optic cable from the TCU to the CD changer is then attached from the output of the sirius unit to the CD changer. ergo you have a complete circle to the network. I am betting that a fiber optic wire exists and can be ordered from the TCU to Sirius unit (as this is part of the factory prep).
Then you run the two antenna wires to the shark fin into the trunk (also presumably part of the factory wiring kit) and use the power cable alread existing. If one of the connectors is wrong they can be ordered from BMW and changed.
THis will be my thanksgiving weekend project and will be coded on Monday assuming the wiring is succesful
I will update upon completion. Wish me luck!
[snapback]59736[/snapback]
Good luck Lenk, let us know how it goes. I don't doubt you can install an aftermarket unit and get it power or even connected to the network, but there is a software install from BMW required for the unit to be integrated w/ the iDrive. If you can make this connection so as to avoid the lower quality FM modulator option, let us know.
Old 11-23-2004 | 11:40 AM
Lenk's Avatar
I intend on using the BMW Sirius Box. I am only making my own retrofit kit.
Old 11-23-2004 | 12:10 PM
530iii's Avatar
My Ride: E60 "Stripper" Now C6 "Stripper"
Originally Posted by kscarrol' date='Nov 22 2004, 08:20 PM
[quote name='530iii' date='Nov 22 2004, 07:56 PM']Invoice of 70 bucks? Come on BMW should just make Satellite Prep standard!
On 2005 E60's if Navi is not ordered you don't even get Navi Prep (Menu and voice buttons)! <_<
My 11/03 production had'em!
[snapback]59680[/snapback]
That may be true, I was simply asnwering the question of what Sat Prep was.
[snapback]59696[/snapback]
[/quote]
BMWNA are you listening? Give us more bang for our buck!
Old 11-23-2004 | 12:13 PM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
[snapback]59935[/snapback]
But you're not going to have the BMW software for iDrive integration? I'm confused, which isn't hard to do by the way... You've got Sat prep, you're using the BMW Sirius unit, but you're doing the install yourself, right? The only piece missing is the software. Or are you not going to integrate w/ iDrive?
Old 11-23-2004 | 02:48 PM
PabloR's Avatar
Originally Posted by kscarrol' date='Nov 23 2004, 04:13 PM
[quote name='Lenk' date='Nov 23 2004, 01:40 PM']I intend on using the BMW Sirius Box. I am only making my own retrofit kit.
[snapback]59951[/snapback]
[/quote]
Lenk,
do you have nav? I think that in MY04's there was a problem with nav and sirius where they made a harness change in order for the two to play together. So even with the sat prep (which I dont have), it does not work. You think it will?
Pablo
Old 11-28-2004 | 09:58 PM
tedmundson's Avatar
My Ride: 2005 530I Prem Package, Cold Weather, Prem Sound, Bluetooth and Sat.
lenk any updates to this....
Old 11-29-2004 | 09:16 AM
Guest
Guest
Posts: n/a
I hope you took pics! Did it work?
Old 11-29-2004 | 09:07 PM
Lenk's Avatar
To All:
I have no nav and no sat prep. kit but intend on using the BMW sirius reciever. The sat prep kit comprises three sets of wires: fiber optic connector to connect to most system, power and antenna. The power and the antenna are easy to retrofit. The only problem is the fiber optic conector. I believe the fiber optic connector is merely a fiber optic wire that loops through the most bus conncetor in the back left wheel well but need to look at a prepped car to verify this or a picture/illustration of the installed sirius receiver to ee how the fiber optic connector is done. I can't find an illustration of the wiring of the sirius reciever on BMW TIS. I thought the receiver was connected in network from from the phone TCU to the sirius reciever back p to the cd changer, but I now believe it is just looped through the MOST fiber optic bus connector in the back left.
Any info would solve the problem and would be the key to the puzzle.
Old 11-30-2004 | 07:33 AM
craigt-from-atl's Avatar
[snapback]62350[/snapback]
Sorry Lenk, no answers, but I am VERY interested in how this works for you. Possibly even write up a DIY for us?
I'm in the same boat, no NAV, no SAT Prep, but want sirius integrated.
Thanks!
Craig
Old 11-30-2004 | 01:24 PM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Welcome aboard, craigt-from-atl !
