SA Question (Rudy!?!?)
My Ride: 2011 M3 Convertible, Alpine White/black, 6 speed
2011 535xi Tasmin Green, Venetian Beige
Something confuses me. When I move the shifter to the left the gear indicator says S mode which changes to M as soon as I hit the flipper. I know that when it's in regular automatic mode I can push the sport button but what is this other mode?? If it is Sport mode then I don't see how it's different from the regular Sport automatic mode when the shifter is in the middle. It goes into effect whether or not the Sport button is pressed.
Thanks (as always)
Jeff
Thanks (as always)
Jeff
Thanks (as always)
Jeff
Thanks (as always)
Jeff
My Ride: E90 M3
Model Year: 2011
I don't claim to fully understand the difference either. The use of Sport mode by moving the shifter over raises the shifting points for the tranny, but so does the Sport button. The manual very briefly describes the Sport button activating Dynamic Drive which adjusts steering response and otherwise tweaks engine speeds. So basically it seems like the S mode in the tranny seems to only adjust the shift points but the Sport Button makes other adjustments to the driving experience...
Others will have to fill in the detail, but it would be nice if the manual provided more color as to what these modes did...
My Ride: G30 M550i
Model Year: 2018
Read the following thread about the SAT (not SA -- that means Service Advisor...
) to see if it helps you understand things better:
http://forums.e60.net/index.php?showtopic=43318
If you're impatient and don't feel like reading the whole thing, here's a post where I outlined the six discrete modes:
http://forums.e60.net/index.php?s=&sho...st&p=457870
) to see if it helps you understand things better:http://forums.e60.net/index.php?showtopic=43318
aqualibrium
Jul 21, 2015 03:11 AM
