Rusty & Crusty PANIC!
Old Sep 25, 2012 | 04:33 AM
kskane's Avatar
My Ride: E60 M54
Model Year: 525i 2004
To all Bimmer DIY'rs, I opened up my M54 value cover on the E60. Inside the valve cover, on the right side there is a plastic over (image attached) which you see when you open the cover where the oil is poured into the engine. That cover which is plastic, was covered in RUST.
When I looked at the valve cover (image attached), it was covered in RUST in L-Shape, above the plastic cover I explained above and along the VANOS.
How come there is rust on plastic parts and should I be worried??? I was originally worrying there could be sluge in the engine, but it is RUST. Any similar experiences are welcome with remedy how to clean and avoid in future.
Old Sep 25, 2012 | 09:29 AM
pcy's Avatar
pcy
you are positive that is rust? May be oil sludge baked due to heat, making it look like rust...
Old Sep 25, 2012 | 11:05 AM
dawid_w's Avatar
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
Hi,
Did you ever overheat this engine? It looks like that oil is burned into the engine head (red color).
I opened few engines and usually I see light honey color.
How many miles on the car?
Old Sep 25, 2012 | 05:16 PM
AchtungE60's Avatar
My Ride: E60 530i
Rust on plastic. I think i've heard it all.
Look at my previous post.
https://5series.net/forums/topic/110...1#entry1310886
Your engine appears to be a darker color indicating long service intervals or lack of oil change and hotter temperatures than normal. This is just burnt synthetic oil. Besides....plastic doesn't rust
Old Sep 25, 2012 | 05:49 PM
kskane's Avatar
My Ride: E60 M54
Should I clean the engine area then or just leave it? This is the first time I am opening the engine, have no idea what was done to it previously. I have never had the engine overheat, atleast the car never said it was heated (apart from one instance, but that came and went away by itself).
doughboy540
May 3, 2013 09:59 AM
sotek
Jul 22, 2011 02:39 PM
Howitzer
Apr 15, 2010 10:44 AM
jas_r_1
DIY: Do It Yourself
Oct 11, 2009 01:31 PM
dmw5678
Detailing Forum
21
May 26, 2006 05:26 AM
