Running in a 535d
Old May 6, 2005 | 08:08 AM
sapkan's Avatar
My Ride: 535d (4/05) M Sport, Carbon black, Black dakota leather, Sport seats, Xenon, Navi prof, Hi-fi pack, AS, BT, PDC, Sunroof
Old May 6, 2005 | 08:20 AM
garehaan's Avatar
My Ride: 2011 520dA coming up.
3600 rpm = 150Mph! in 6th with the diesel so you'd be running out of scale when you even could do 4000rpm
Keep it running at different rpm as much as possible by simply using the manual option of the gearbox.
Let's say you have to drive 130-140km/h then simply shift back and forth between 5th and 6th gear every few kilometers. Otherwise try varying your speed.
Good luck and enjoy!
Old May 6, 2005 | 08:23 AM
sapkan's Avatar
what is the technical explanation for the need to vary your engine speed during break in
Old May 6, 2005 | 08:27 AM
GPS's Avatar
GPS
[snapback]124969[/snapback]
to make sure the engine, transmission and all mechanical parts get progressively used to all possible regimes, I guess
Old May 6, 2005 | 08:40 AM
Gudge's Avatar
Originally Posted by GPS' date='May 6 2005, 05:27 PM
[quote name='sapkan' date='May 6 2005, 06:23 PM']what is the technical explanation for the need to vary your engine speed during break in
[snapback]124970[/snapback]
[/quote]
Hmm.........Does not sound like a definitive technical explanation to me.
I've been told not to go much over 4,000 revs for the first 1200 miles.
I'm actually quite enjoying it..........trying to see if I can creep above my personal best of 32mpg. I've not had a motorway run yet though.
Old May 6, 2005 | 09:52 AM
BMW535d's Avatar
Don't baby it too much.
Don't be afraid to touch 4k rpm within the first 1000 miles on ocassion.
3/4th of throttle is like almost full throttle anyway, the only thing kickdown does is pulling it completely to redline.
Good luck and safe driving!
Old May 6, 2005 | 12:01 PM
GPS's Avatar
GPS
[snapback]124975[/snapback]
?Break-in,? for the most part, is the allowance of the machined cylinder and ring surfaces to conform to each other?s shape during engine operation. This conforming or ?mating? of ring and cylinder surfaces is the ultimate goal of a proper break-in. ?Mating? these two specific parts will produce a very tight seal in each cylinder. A tight seal is very important because it prevents the escape of unburned fuel and pressurized gasses into the crankcase, while further preventing crankcase oil from entering the cylinder above the top compression ring.
Does this sound technical enough?
Old May 6, 2005 | 12:48 PM
sapkan's Avatar
Originally Posted by GPS' date='May 6 2005, 10:01 PM
[quote name='Gudge' date='May 6 2005, 06:40 PM']Hmm.........Does not sound like a definitive technical explanation to me.
[snapback]125043[/snapback]
[/quote]
top notch, thank you
Old May 6, 2005 | 01:27 PM
Merv the Derv's Avatar
My Ride: 535D Sport Auto
With my last 530d I just avoided the kick down click. Same with the 535d.
You won't need to go above 3,500 rpm to have some fun. Its all about low revs in the diesel's.
Old May 6, 2005 | 02:51 PM
AfroBMW's Avatar
I was told at the Euro Delivery not to pass the 3500rpm mark for about 2000Kms and of course "AVOID KICK DOWNS ". The funny part was that the dude never told me about a speed limit, so I took mine to 220Km/h for about 2 hours (coming from Munich to Berlin). I broke her in the first week and all seems well. Just waiting for the fuel consumption to improve though.
