Runflats to non runflats
My Ride: BMW 530d SE. Media Package, Sight and Light Package, Front and Rear Park Sensors, Active Steering, Dynamic Drive, Power Folding Dimming Mirrors, Active Cruise Control, Logic 7, Sunroof, Sports Steering Wheel, Advanced Aircon, Comfort Seats, Heated Seats, Oscillating Seats, Air Cooled Seats, Electril Rear Blind, Rear Heated Seats.... probably more that I have forgot! :p
Hi,
Going along the road the yesterday when BAM! IDrive popped up and said I had a flat tire!
Pulled over and looked at my tyres and couldn't see a problem. Drove some more and couldnt feel any issues either. Went into the local garage and took the wheel off, MASSIVE GASH where the wall had came away from the base of the tyre! WTF! the tyre was quite a bit more worn on the inside edge than outside so I had never noticed this.
The question is now, I want to put 19" 172's on my car anyway without runflats so instead of buying a new runflat I am getting the 172's. How will I clear I drive of saying I have a puncture if I put standard tyre 19's on?
Thanks,
Lee.
Thanks,
Lee.
So does the tyre warning system still work with non-runflats?
It's a Nov 2004 car if that makes a difference?
My Ride: G30 M550i
Model Year: 2018
Once they're all mounted and at the proper psi, just reset the FTM system and enjoy.
Excellent, I knew it would be you that came along and confirmed this Rudy! Was just reading your other post which confirmed it too... http://forums.e60.net/index.php?showtopic=...amp;hl=run+flat
Cheers,
Lee.
Cheers,
Lee.
i guess it would work..
here is a topic about reseting the ftm
http://forums.e60.net/index.php?showtopic=...onitor&st=0
and here is the link to the faq
http://forums.e60.net/index.php?showtopic=2111
Thanks Bilbo.
For any future people finding this if you have rubber stems for inflation valves on your wheels (like me) then your car uses the ABS to callaborate the tyre pressure system and you can just fit any tyre/wheels you want. Use IDrive in Bilbo1's posts above to reset the sensor before driving a few miles on the highway to make the system ready and active.
Originally Posted by Rudy' post='575014' date='May 6 2008, 11:56 AM
Yes, you'll be fine -- the warning system is not dependent on the tires...
I enquired at the local KwikFit (a not-very-good tyre depot in the UK) and they told me the dealer was right and that they would not fit non-runflats to my rims.
I had to bite the bullet and get three new runflats to get the car through the MOT test
My Ride: G30 M550i
Model Year: 2018
Originally Posted by cjbryce' post='575053' date='May 6 2008, 10:29 AM
Mmm - how can I confirm this? I wanted to put better tyres (i.e. non-runflats) on my car at the MOT test (annual government standard test for cars > 3 years old), but the $tealer absolutely insisted that the RPA would not work and if I wanted non runflats I'd have to change the rims from the factory-fitted rims.
If you're still skeptical, watch how many other replies this thread gets that verify what I'm saying (hint, hint.) Aside from the usual wise guys who are going to post something silly, I think you'll find that the overwhelming majority of members here will confirm things (and possibly even recommend a different dealer for you to use in the UK...)
Having said all of that, although the ride is a bit harsher, many people still find the runflats worth having because of the extra convenience and safety that they provide.
My Ride: E90 M3
Model Year: 2011
As usual, Rudy is absolutely correct. Many, many people have switched from RF tires to non-RF because of premature wear issues, road noise and poor ride quality. They kept the stock BMW factory rims and there were NO issues. It is really sad how many dealers are misinformed about this issue and frankly the E60 in general.
