Rotor Replacement? Warranty Service?
My Ride: 2007 550i Jet Black|Black
Options: Sport|Premium|Cold Weather|PDC|Nav|Satellite Radio|Active Steering|Convenience Entry
Mods: Trinity Side Skirts|Trinity Black Grilles|LCI Tail Lights with Bruce V6|Fog Light Bezel Rings|MTEC V2 Angel Eyes|LED License Plate Lights
I took my car into the dealer today for brake service. I have the "extended maintenance package".
When I picked up the car, I saw that they had checked the pads (3mm) and the rotors (22.9mm and 22.7mm). They replaced the pads and sensors but NOT the rotors.
I have had BMWs for 10 years. When my last car (e39) went in for service they ALWAYS replaced the rotors when they replaced the pads. (At that time I didn't have maint coverage). They insisted you had to change both at the same time. Now - when they are paying for it they didn't change the rotors.
So are my questions:
(1) What is the minimum acceptable spec for rotor thickness - I have a 2007 550 Sport
(2) Does BMW maintenance call for replacing rotors when replacing pads or is it based on the thickness of the remaining rotor?
(3) Generally, with average driving what is the rule of thumb for rotor wear (that is mm wear per miles).
Thanks!
Thanks!
I did some research and it appears the min tread for the rotors is 22.4mm. That means I am 80% down on one rotor. I can't believe they didn't change them. Has anyone dealt with this type of situation before?
My Ride: 07 530i Mystic Blue
I have the extended maintenance package as well. My rear rotors have never been replaced and they started squeaking. Thus, I took it to the dealership to have the brakes checked and rotors measured. Rear rotors for my 530i minimum spec is 18.4mm and they were measured at 18.3mm. They would NOT replace the rotors eventhough they were below spec! They told me that rotors are ONLY replaced in conjuction with brake pads. Therefore, I was asked to bring back when I am due for the rear brake pads, which would be in another 20k miles. Even called BMWNA and they told me that they would have to follow whatever the dealership determined. I was frustrated. First, I didn't want to compromise my safety and secondly, I was annoyed by the squeaking sound.
I ended up purchasing aftermarket rotors/pads from Michael (Acuteperformance) and replaced them myself.
If you didn't have the extended warranty - I bet they would recommeded to replace the rotors and pads together.
EDIT - minimum specs
I have the extended maintenance package as well. My rear rotors have never been replaced and they started squeaking. Thus, I took it to the dealership to have the brakes checked and rotors measured. Rear rotors for my 530i minimum spec is 28.4mm and they were measured at 28.3mm. They would NOT replace the rotors eventhough they were below spec! They told me that rotors are ONLY replaced in conjuction with brake pads. Therefore, I was asked to bring back when I am due for the rear brake pads, which would be in another 20k miles. Even called BMWNA and they told me that they would have to follow whatever the dealership determined. I was frustrated. First, I didn't want to compromise my safety and secondly, I was annoyed by the squeaking sound.
Wow - that's crazy that they would send you out with rotors below spec!
Edited my typo in the previous post. Mine were at 18.3mm when minimum spec is 18.4mm. It's even stated on the receipt. Ridiculous and total BS.
I surely was not going to drive another 20k until they were going to replace the rotors. Subsequent to my dealership visit, ordered the aftermarket parts same day. I wanted less brake dust anyways, so went ahead and opted for aftermarket parts. Were actually cheaper than OEMs. Very happy with them.
It sucks, but I feel your pain - it's not surprising to me that they didn't replace your rotors.
My Ride: 2008 535i:
1992 Camaro RS:
Front brakes or rear?
Something must have changed. I brought my car in for squeaking front brakes earlier this year and got both new pads AND rotors installed under warranty.
My front break needed service, took it to the dealer, they replaced break pads along with rotor with out any questions. I believe its more depends on the Dealer. I just replaced the rear (out of free original maintenance) my self with BMW OEM parts (rotor and pads with sensor) for less than $260.
chadillac2000
42
09-13-2017 11:15 AM
SaltyDawg
05-19-2015 02:41 PM
TexaZ3
05-06-2015 09:54 AM
