rotor/pad recommendation
Old 05-10-2016, 02:52 AM
JuniorB's Avatar
HI,this may be to late,but I did a complete upgrade,550 calipers,slotted,drilled rotors,ceramic pads,ss brake hoses.looks awesome
Old 05-10-2016, 04:54 AM
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
Originally Posted by BostonJon
i'm familiar with them but didnt know they were still in business - website isn't working at the moment.
for my driving - with is only around town and some highway - i'm not convinced that drilled/slotted is really necessary or appropriate.
Agreed. For our purposes, drilled and or slotted brakes is only for appearances and there are disadvantages to drilling - less braking area and risk of the disc cracking.
Salut, Bob P.
Old 05-15-2016, 07:51 AM
JuniorB's Avatar
Hi,I've read pros and cons with the rotors, they come stock on a lot of high performance cars,so they can't be that bad. I do a lot of hi way driving so there perfect for me. I think I may have purchased the wrong pads tho,they are ceramic,but I couldn't find a ton of reviews but I gave them a shot spectrum 3000, I'll do a check in when I seat them in. I'll try anything once
Old 05-15-2016, 08:04 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
Just like with any product, there are good and not-so-good brands. The Akebono ceramics get good reviews.
Old 05-15-2016, 12:42 PM
JuniorB's Avatar
That's probably the best all around pad in all the readings I have found,I gave these a shot,those are my back up.
Old 05-18-2016, 11:20 AM
BostonJon's Avatar
My Ride: BMW 530xiT (E61)
hey everyone. thanks for your suggestions. i ended up going with the zimmerman coat z rotors and akebono ceramic pads. while i had all the tools out, i replaced all four of the original brake lines and did a fluid flush since i had the system open. since i had a hand-help mityvac pump, i decided to use that. initially i was concerned that it wouldnt be as effective as the pressure method (i.e. a motive), but it went really well to get all the old fluid and air bubbles out.
i'm still getting used to the different pedal feel of ceramic pads vs. the OEM metallic pads. as so many others have noted, there is definitely less bite on initial pedal press, but the brake response seems more linear than it did with the OEM pads. i'm sure ill get used to it pretty quickly.
next project: fuel filter
https://5series.net/forums/diy-do-yo...t-swap-121415/
Old 07-14-2016, 08:26 AM
89mustaine's Avatar
My Ride: 2008 535i Sport
If I simply got slotted but not drilled (mostly for looks) would that have a negative effect on pad wear?
Also does anyone have experience with the black coated rotors? I have black wheels and I'm not convinced they would look good but it's something different I'd be willing to try.
Thoughts?
Old 07-15-2016, 10:55 PM
rice_rocket88's Avatar
My Ride: 2008 535xi
Engine: n54
None will have a negative impact, they are functional for a reason. People do argue that hot track temperatures could make them more prone to crack. For street duty it's fine. The black ceramic coating is for the non contact surfaces, ie the hubs and edges, which is really nice when they resist corrosion. Don't be fooled into thinking the actual surface of the rotor will remain black. Most good rotors are still zinc coated so it resists corrosion anyways.
Thoughts?
Old 07-18-2016, 01:57 PM
westsidebalto's Avatar
My Ride: Sold: 545i, sport package, cold weather, 6MT
Engine: N62
Originally Posted by JayArras
Zimmerman + Akebono pads would be my vote.
My indy has run into Zimmermans warping. I went OEM rotors and Akebono pads though. SOOOO much less dust.
Techno79
04-25-2016 04:25 PM
ThaDannyP
04-21-2016 07:58 AM
revenge
04-20-2016 01:31 AM
dj_m5
04-15-2016 09:38 AM
Quick Reply: rotor/pad recommendation
