right rear wheel sits lower than my left. HELP!
Old 05-24-2015, 07:25 PM
myxyzxo's Avatar
My Ride: E60
Model Year: 2010
realoem.com or getbmwparts.com. Provide information about your car, prices are there. About $134.00, dealer price is around an additional 35.00
Old 05-25-2015, 02:41 AM
cmyachtie's Avatar
My Ride: 2004 545i+BT+AUX+Coding
Engine: N62
This may help......
https://5series.net/forums/e60-discu...-again-138580/
Broken rear coil springs are somewhat common.
Old 05-25-2015, 11:25 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
Originally Posted by rmendoza.2611
Are joking or being serious?
Being serious. You can check for a bad spring or shock, but don't forget your big heavy battery is over there.
Post pics of the car.
Old 05-25-2015, 11:37 AM
rmendoza.2611's Avatar
My Ride: 2008 550i M-Sport
Here they are
Attached Thumbnails right rear wheel sits lower than my left. HELP!-14325824412181311459214.jpg   right rear wheel sits lower than my left. HELP!-1432582534440-833089265.jpg
Old 05-25-2015, 03:29 PM
cmyachtie's Avatar
Engine: N62
Here they are
Looks like broken spring to me, i'll put money on it, mine did look just like it ....
Old 05-25-2015, 05:24 PM
Would it be better to buy each size a lowering spring instead?
Old 05-26-2015, 03:24 AM
cmyachtie's Avatar
Engine: N62
Yes you can,......
Then you need to do both front AND rear.
Old 05-26-2015, 08:10 AM
tundra's Avatar
My Ride: e60 550i M-Sport, 6mt
By all means check if your spring perch is damaged and the spring is not supported. However, I wouldn't be surprised if you don't find anything wrong with it.
BMW sets the ride height assuming the driver is sitting in the vehicle. This means that the passenger side will be lower than the driver side with nobody in the car. On my 550i M-sport there was almost 1" difference ride height in the rear from passenger to driver side.
Take a measurement on the driver side rear with no occupants, then sit in the car and have your buddy measure again. The ride height will be similar to the passenger side when you're sitting in the car.
Old 05-26-2015, 10:28 AM
You guys wouldn't know if the 550i msport come with air suspension?
Old 05-26-2015, 10:31 AM
Well when I noticed it there was nobody in the car at all. And today I told my buddy to get in the car and I looked at it and there's still a difference in the gap.
Quick Reply: right rear wheel sits lower than my left. HELP!
