Sponsored by:
Sponsored by:
Right License Plate Light Not Working
Old 06-27-2017, 10:04 AM
donpb's Avatar
My Ride: '06 530i N52
Unhappy Right License Plate Light Not Working
I got an alert last week that the right license plate light was out. The light bulb had simply burned out. I replaced the light bulb and the alert went away and all was well. Then a day later I got the alert again.
The light was out.
I did a continuity check on the light socket and the bulb and it has continuity. I removed the socket and there is no voltage at the connector.
The left license plate bulb is working just fine.
Is there a fuse or something that could be open causing this or why is there no voltage coming out of the socket?
Old 06-28-2017, 07:10 AM
brow@garlic.com's Avatar
Default Broken wire
I started having electrical issues with the trunk and checked the wire loom that come through the right strut. Broken wire! it started as intermittent error.
Old 06-28-2017, 07:55 AM
rice_rocket88's Avatar
My Ride: 2008 535xi
Engine: n54
Probably broken wire loom in that trunk as brow mentioned..
Old 06-28-2017, 02:59 PM
donpb's Avatar
I believe that would be item #5.
Attached Thumbnails Right License Plate Light Not Working-e60-wiring-loom.png
Old 06-29-2017, 04:30 PM
E60AUS's Avatar
My Ride: E60 M Sport 530i
As others have said, it is the wiring in trunk lid hinge. Read the thread 'very unusual boot opening problem ' and read my posts there and you will find the info you need to fix..
Ralph Avery (03-19-2021)
