RFT & Tyre Pressure Sensors
Thanks for answers to my previous post. Apologies if this one seems obvious.
Am I correct in thinking the tyre pressure sensor system is independent of run-flat-tyres??
What I mean is; if I change rims (w) rft to larger rims with conventional tyres; do I forego the tyre pressure gadgetry??
It would seem conventional tyres offer a more supple ride than rft size for size??
So in essence the natural ride degradation from going up 1 or 2 inches in rim size can be negated (somewhat) by the change to conventional tyres?? How am I doing here??
Is there any other benefit from rft: -
Puncture resistance
Tyre life
Rolling noise etc etc etc
Thanks in advance
Thommo
Puncture resistance
Tyre life
Thanks in advance
Thommo
You are correct.
Nope
Agreed.
You are doing fine. You would choose tires that have lower profiles than your originals so that the diameter of your tires is unchanged.
Maybe quieter; smoother ride; better performance; lighter (OOPS, backwards answer)
Puncture resistance
Tyre life
Thanks in advance
Thommo
You are correct.
Nope
Agreed.
Puncture resistance
Tyre life
Thanks in advance
Thommo
My Ride: G30 M550i
Model Year: 2018
[/quote]
Are these benefits to conventional or RFT??
I'm guessing with the stiffer side wall the only benefit to RFT is puncture resistance (a long shot perhaps?) and maybe Rim protection (even longer shot :-( )???
You are doing fine. You would choose a tires that have lower profiles than your originals so that the diameter of your tires is unchanged.
Youre right Rudy but i reckon we're on the same page.
[/quote]
Huh, wtf?? Free tyres??? Please elaborate.
I'm not convinced RFT's improve tyre life. The Dunlops lasted me just 14,000 miles! (I expect my PS2's to last longer!) I think the life is influenced by other factors...
Rolling noise? Hnmmmm, again I don't believe RFT's alone affect this - although my guess is that they would be worse rather than better!
Having myself changed from RFT's (Dunlop to Michelin PS2) I can confirm the ride is definitely improved (for me). The main difference I feel is the drastic reduction in tramlining and the 'skipping' effect over small holes/lumps has gone...
Tire pressure system works with ABS sensors. No problem at all if you use other rims/tires. You've just to reinitiate the system after fitting the new rims/tires.
I'm not a fan of the RFT. So I advise you to go for traditional tires : cheaper (-20%), more confortable, less tramlining. But then you need to buy a spare wheel.
Wider tires are better for the look. But there are also disadventages : less miles, more sensible to aquaplaning, tramlining, ...
I think that 245/40R18Y is a very good compromise. And for the look, you might use 10 or 15mm spacers on each wheel.
[/quote]Hi Rudy: You definitely are right on the second count. I think I interpreted his first question right though--just wanted him to know that the switch to conventionals usually entails lower profile tires. I was replying last night needing some rest after our trip. Brain was not engaged.
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
![Drool](https://5series.net/forums/images/smilies/imported/drool.gif)
![Stuart](https://5series.net/forums/images/smilies/imported/stuart.gif)
