RFT repairable?
My Ride: 2007 BMW 550, Sport, Navi, PS, CWP, Sirius
I was informed by my dealer yesterday that my right front tire caught a nail. The dealer does not want to patch/plug the tire. Is there any tire shop in NYC/NJ area that would do it? Thanks in advance for any info.
If it is near the edge of the tread or in the sidewall, the dealer is 100% right, IMO. But, if it is well within the tread, patches seem to work OK. If I ever need one patched, it will be from the inside and not a plug. Most of the tire chains like NTW and Discount Tires will repair RFT, but their first option will be to plug. If you insist, they will patch from the inside.
I have not seen the car yet. It's been in the dealer's hands since Tuesday. The car needed another engine repair. Second in 14 months. They noticed a nail in the left front tire. There was not any warning from FTM or any air leak before I broght car in for repairs. I believe the tire sidewall is not damaged otherwise FTM would probably catch it.
My Ride: 2006 535d MSport ; Retired at 110,000 miles
October 2010: 2010 535d MSport; Space Grey/Black Dakota, Adaptive Xenons, High Beam assistant, Prof. Nav, Voice Control,SAT, Adaptive Drive, Powered boot, Comfort Access, Climate Comfort W/Screen, Surround View, Side/Rear Sunblinds, Comfort Seats, HUD, Active Cruise, TV, Prof Loudspeaker, Night Vision, Lane Change warning, 4-Zone A/C, split rear seats, Speed Limit Display
Might be different rules in the US, but my understanding was that Run Flats cannot be repaired; once theyve lost pressure and relied on the sidewall, even if for a short distance, the tyre must be replaced.
On my last E60 I ended up having 2 changed because the tyreshop wouldn't repair them; I called Goodyear's customer service line and they confirmed that their advice to tyre shops was never to attempt a puncture repair on RFTs.
Needless to say, I've had the RFTs swapped for 'ordinary' tyres on this E60!
officially, you're not supposed to patch rft's
unofficially, you can patch rft's with no problems
My Ride: '04 525i, sport package & all the other goodies included
wooboodoo
10-25-2015 02:58 PM
