revisions to 535d engine for facelift
One missing change:
Piezoelectric injectors instead of ceramic ones
However i had no idea about the transmission new improvement.
About steptronic paddles steering wheel, I am in process to change to it, by a DIY motion, I had not idea of BMW going to offer it as std.
My Ride: 320d SE (E90) manual - Sapphire Black, Beige Leather Sports Seats, Burled Walnut, Heated Seats, Sunroof, Comfort Access, Hi-Fi sound, Bluetooth, Side-Window blinds, Through-Load, Luggage Net, PDC Front & Rear, Adaptive Xenons, Style 158 17", Chrome Grill & Window Trim, Blackline Tailights, Power folding/dimming side mirrors, Split Armrest, Dual Zone Climate, Cruise, LEDs on door handles, iPod nano, SE K750i
Originally Posted by inmediate' post='361072' date='Nov 27 2006, 04:28 PM
One missing change:
What are the benefits of Piezoelectric versus ceramic?
Originally Posted by Raighne' post='361083' date='Nov 27 2006, 04:42 PM
That's interesting. Didn't know that.
What are the benefits of Piezoelectric...
On the other end of the scale sit piezoelectric injectors. They can cycle twice as often as magnetically triggered injectors, so short duration injections can be used to generate mixture flows that are easily ignited. Plus, this injector?s circular side opening creates a cohesive cone-shaped stream flowing from the top center of the combustion chamber, and can be timed to produce a charge of varying density. Its big disadvantage is that it is larger and more expensive than magnetically operated, multiple aperture injectors.
Piezoelectric injectors, however, may prove to be invaluable in future clean diesels because the quick on-off feature gives engineers greater leeway in spray timing and density, which has a tremendous effect on the noise and pollution emitted by compression ignition engines. ?Intervals between individual fuel injections can be reduced,? says Dr. Ulrich Dohle, president Bosch Diesel Systems, ?which gives greater flexibility in meeting power, economy, and emission goals.? The advanced diesel piezoelectric injector locates several hundred thin crystals within the injector body. The movement of the piezo wafers?they expand in the presence of an electric field?is transferred to the nozzle needle in less than 0.0001 seconds, and its inline design means very little fuel return flow is needed. This reduces the delivery rate and energy required from the high-pressure fuel pump.
?The key to improving fuel consumption and reducing emissions from a diesel engine,? says Dohle, ?is to reduce internal engine emissions through optimization of the basic engine design, and improvements in the injection strategy itself.? Adding one or two pre-injections stops smoke generation just after a cold start, which also reduces combustion noise. A post-injection immediately follows the main injection to lower soot emissions, and a further injection can be added to regenerate the particulate filter. Compared to existing magnetic or piezoelectric systems, Dohle expects a common-rail system with piezoelectric inline injectors to cut internal engine emissions by as much as 20%.
ABC
As far as I know It improves the enviroment.
Std injection was divided in two cycles
a.- Pre Injection. Adapting the engine to pressure and temp as well as vibrations messure.
b.-Main Injection. Combustion
The problem was how to eliminate the little particules remaining
1.- By a separate filter. meaning maintenance
2.- Creating a 3rd cycle, as to "burn" those small parts.
This is mainly what a Piezoelectric injection system was created for. To comply with a new EU directive related to emissions to the athmosphere...
Regrds
Thanks for all the great information.
It also sounds like (from ABCs post) some side benefits are (i) reduced noise (ii) slightly better economy (iii) slightly more power
Is the slightly increased power/torque and better economy of the revised 535d then mainly due to the piezos, to the weight reduction or both? Also, is the reduction in noise in any way significant?
I have reprogrammed it much further than 286 hp and 580 Nm torque. So I wonder if at BMW they have also gone that way.
My Ride: 2001 BMW 316ti, 2004 BMW 530d, 2006 BMW 530xd, 2013 BMW 320d touring, 2014 BMW 520d touring, 2016 BMW X5, 2020 BMW 320da touring, 2020 BMW 540i
Model Year: 1974
Engine: Flat six
It will be the same engine than the 3 and the new X5 ?
Yes it is supposed to be the same
kind regrds
Edit: how much of the noise reduction is due solely to injectors, is anybody's guess, but I expect the new 535d to be quieter (or rather, smoother sounding) than the current one.
The new X5 will initally only come with the 3.0d (single turbo) when it ships in Europe in March/April 2007
No word yet with the bi-turbo will be introduced in the X5 but people are guessing towards the end of 2007 or early 2008.
