"Restraint System Faulty"
#21
OKay Back from the dealer...
Plenty of Bullshit from that experience, but for this topic, they said it is the passenger side front seat mat sensor.
It has thrown the error 3 times...
CURIOUS? Is there a bypass so i do not need to pay the $990 if this happens again...(Or use a bypass before it does..?
#22
Yea I just want to disable it. This error doesn't effect the driver side airbag does it? I'll just let my passengers know they need to wear a helmet.
#23
ha ah aha...
but seriously, is there...
i have heard so many storeys of repeated errors after fixes....
does the airbag have this feature (where it doesn't deploy if no one is sitting there) on all models...?
#24
Hi Mate,
I had a seat mat failure. Went on ebay and paid £8. Thought this wont work. 10 minutes to do the job. Under the seat there is a cable going to a black box. Cut the cable halfway to the seat and bare the ends and attach to the bypass unit.
I had some diagnostics to switch the airbag light off. If you dont have you will need to get the light switched off. A clever little unit, you dont get a seatbelt warning if the person on that seat doesnt put a seatbelt on.
Beats paying 100s though. Light has never came back on.
Good Luck
Fraseman
Good Luck
Fraseman
#25
Anyone know if this works on North American cars? My car isn't covered under the recall nor is warrantied.
Hi Mate,
Good Luck
Fraseman
Good Luck
Fraseman
#26
#27
If your looking for restraint cables I suggest using http://www.cmacable.com
#28
hi guys
i jus had this problem fixed a few days ago from dealers.....at first i had the lights switched of by independent garage, but it come on again, this happened twice.....so it wasnt a random code in my case. had it checked from dealer,where my mate works. And he advised high resistance in around the explosion cable/battery cable.
worst case, new battery cable at about £100, or he said he thinks its the little wire that attaches to the battery cable, at a cost of £30. so he replaced the cheaper one first, and this seems to have fixed it now.
hope this helps you
hope this helps you
#30
Hi, am new here and just bought a used 530 and it has this problem Restraint Systems Faulty. I've told is that mat sensor and dont want to change it before am sure thats the problem. Can one of you guys tell me about the wire connected to battery? Which one is that and where it leads? Picture would be the best!
Thanks in advance Agron!
