Resetting transmission
Hi guys,
I own a 2004 E60 525i.
It has automatic transmission.
This morning, The engine run very roughly during the cold start.
I decided to turn it off, and wait for 30 seconds and start it again.
It was running fine.
However, whenever I stopped I can really feel the transmission shift from 2nd gear to 1st gear.
It is very rough. I remember a topic on how to reset transmission before in this forum, but I couldn't find it anymore.
Anyone knows how to do it?
Thank You
Yoko
Thank You
Yoko
hey bro, better check better next time. just found it at the bottom of the E60 discussion. Cheers BRO
http://forums.e60.net/index.php?showtopic=40018
Turn off car. Turn key to position two (electronics on, but no ignition). Push accelerator to the floor and hold for 25-30 secs. Release. Move key back to initial insert position. Then restart car.
I'm sorry about not checking it better.
I checked it before in the DIY section.
Thank you.
Yoko.
thank your for your information.
My last question is:
do I need to reset it in the morning when the engine is still cold?
Thank you.
Yoko.
Originally Posted by Yoko' post='644301' date='Aug 11 2008, 04:55 PM
Thanks a lot.
Thank you.
Yoko.
Thank you.
Yoko.
Hi guys,
I did it just now, but there is no sound coming from the transmission.
The drive is still rough.
My key is still the old model one, would that be the reason why?
Originally Posted by Yoko' post='644440' date='Aug 11 2008, 05:08 PM
Hi guys,
My key is still the old model one, would that be the reason why?![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
the older model key would not be an issue...if you read thru the thread that member btljuice: members with the older key were able to reset their transmission as well. Some did report no sound made, but did report a difference in shifting. Perhaps this is not the fix you need...
My Ride: 03 BMW E60 520i - Steptronic - Black Sapphire - Style 116 wheels (Pirelli PZero Rosso) - PDC - Beige Dakota Leather - Dark Poplar Wood
I have the old key and I was able to reset transmission. Usually, when your driving in D the 1st gear is never selected (correct me if I'm wrong) even after you reset the transmission. Maybe is not a transmission problem but something else.
