Replacing windshield and bobbles under the sensor part
Old Jul 5, 2011 | 02:02 PM
neopoint's Avatar
I am in processing to change the front windshield on my car paid by insurance through Safeguard.
I requested all BMW original parts and got approved. Today, when tech came to replace the window I asked to make sure there are no bubbles should left under the sensor part as I heard others complaint about that.
He said once you put the gel under the sensor he does not know how to get rid of the bubbles even though it has been lined up correctly. Even though he said he installed many windshields on the different cars but there is always be a bubble under neat.
After he talked with his boss, they are going to order some type of injector gel kit that will not create bubbles under neat.
Any expert on this area?
When tech removed the sensor and just put the orginal part back in, I now have bubble under neat.(No big deal as I have to replace it anyway) So I was wondering how BMW or their 3rd party installer are lining up this part? Are they using the injector kit?
I saw safegaurd got the original BMW windshield with the BMW logo on it from dealer with all hardware connectors that sensor snap in to it already attached on it?
Also the plastic mold on the top part of windshield was ordered from BMW.
Any other original parts should they use during replacing the windshield?
I am assuming they can use any standard glue to attached the windshield? Am I correct?
Thank you for your help,
Old Jul 5, 2011 | 04:55 PM
Steveo's Avatar
I would not worry about it and wait till the job was done. If it has a bubble, it's not done right and should be replaced again.
Old Jul 5, 2011 | 11:17 PM
donpb's Avatar
My Ride: '06 530i N52
the better gel will probably do the trick. sounds like they probably knew that already. i bet you dimes to donuts that the non-bubbling gel is more expensive that the bubbling gel.
Old Jul 6, 2011 | 05:19 AM
DavidF's Avatar
My Ride: 545i sport
If the shop has to remove and reinstall teh sensor prism onto the new windshield, then they are NOT using genuine BMW parts. If the windshield is purchased through BMW, it comes with a new prism already affixed to the glass. Aftermarket (or OEM) windshields are available with the prism already affixed to the glass. Insist they use one of the two...
Old Jul 6, 2011 | 08:54 AM
neopoint's Avatar
Hi DavidF:
I look at the windshield and it was a BMW windshield with all hardware attached and BMW stamp. Except the gel part. Is that what you are referring to sensor prism?
All tech did snap the sensor out from the frame that attached to the windshield.
Is the actual sensor and gel should be already attached to the windshield?
Thanks,
socale39
Sep 5, 2023 08:30 AM
DavaiLave
Aug 2, 2022 02:16 AM
Adam1v
Apr 5, 2015 11:40 PM
cidair
Jun 3, 2004 12:26 PM
