Replacing Trans fluid in a stick
Old Jun 28, 2010 | 06:20 PM
AchtungE60's Avatar
My Ride: E60 530i
From what I gather you have a stick. I would not replace that fluid, not would I replace differential fluid. That gear oil is thick and i do believe the MT and Differential oil is lifetime. Do some research. I had an E46 that i attempted to do this on. I used Redline as well. When i drained the gear oil at 133K it was still good. Therefore I put it back in and saved my $. After some research I found that many others experienced the same but went thru with the change and the Redline broke down faster than the OEM. But you have to make your own choice. Me, I wouldn't do it.
AchtungE60's Avatar
My Ride: E60 530i
Old Jun 29, 2010 | 03:49 AM
SilberGrauE60's Avatar
From my experience in other makes, the MT fluid is essentially auto tranny fluid, i.e., not that thick. Yes, the rear diff fluid is usually 90W or something (yes, heavy).
Have you ever been the BavAuto.com? They have some recommendations on maintenance cycles.
socale39
Sep 5, 2023 08:30 AM
pcy
Sep 12, 2021 06:55 PM
Kasmo
May 7, 2019 03:30 AM
kongse
Jul 17, 2015 03:29 PM
BLACK_PRINCE54915
Apr 12, 2015 04:36 AM
