Replacing E60 front parking lamp
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Replace the light. Go to the auto store and purchase one. You should be changing the angel eye bulb. It's a pita but shouldn't take you longer than 10 mins. Replace both because the other one is right behind it
Administrator
Model Year: 05 530i
Engine: 3.0 M54
Pull the bulb out first so you know what you're looking for. If you want the LED version go on eBay and search for it. They can be $10 or $40. It all depends on what you're willing to spend and what you want to do. It's just a small bulb you pull out the casing and put back in
Model Year: 05 530i
Engine: 3.0 M54
Posted the casing your looking for in the headlight assembly and the bulb from advance auto. It's pretty cheap if you just want to replace with halogen bulbs. $7 at advance for the pair
Getting the headlight assembly out was a PITA of a learning curve. Once you get past that, you'll be fine. Scratched my bumper up a bit figuring it out though.
jmk
10
07-17-2011 09:23 PM
