Replacement front brake pads
My Ride: 2006 530i
I have a 2006 530i, I am a little confused regarding replacement front brake pads.
The pads being removed have clips on the backs of both pads, however a new set of Textar pads only have clips on the back of one pad, not both.
I called two different BMW dealers and both said the OE pads only have clips on one of the pads.
Anyone come across this also? Was the part changed?
Thanks in advance.
Thanks in advance.
My Ride: 528xi, premium, navi
Model Year: 2010
Engine: N52
I replaced my pads with Textar also, and like you, the new pads only had clips on one side. I guess it doesn`t matter since the pad isn't going to move and I have been driving for 3000 kms since and no problems.
I just removed mine the other week and had the rotors turned, both of mine had clips. They held the pads in place on the caliper. The inner pad has a metal tab for contacting the rotor if all else fails.
