Replacement battery terminal bolt
My Ride: 2004 BMW 545i - 6 Speed
So I broke off my negative battery terminal "T" bolt this weekend...
Called the dealer to order the part (just the T bolt) and was told they could not order this part, and that it was part of the entire terminal assembly which was over $100 or something rediculous. Needless to say I hung up.
Found out this GM part is a substitute for $6 Here is the part #19116852
(you can order if from Amazon for like $9 or something)
![](https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&ved=0ahUKEwia1s27l9DMAhVGVyYKHYzUCfoQjhwIBQ&url=http%3A%2F%2Fwww.amazon.com%2FGenuine-19116852-Battery-Cable-Tensioner%2Fdp%2FB00GTJQ6TA&psig=AFQjCNG3fQMCYujZmIPXCiUQKMe5f2dVJQ&ust=1462992918904198)
Hope this is helpful for someone in the future.
