Replacement battery terminal bolt
So I broke off my negative battery terminal "T" bolt this weekend...
Called the dealer to order the part (just the T bolt) and was told they could not order this part, and that it was part of the entire terminal assembly which was over $100 or something rediculous. Needless to say I hung up. Found out this GM part is a substitute for $6 Here is the part #19116852 (you can order if from Amazon for like $9 or something) https://www.google.com/url?sa=i&rct=...62992918904198 Hope this is helpful for someone in the future. |
