Replaced Car Battery at Dealer
For the last couple month, I've been getting iDrive messages indicating malfunctions with Dynamic Stability, ABS, steering, flat tire monitor, transmission, etc, etc, etc. So after doing some forum research, I decided to get a replacement battery from a BMW dealer (thinking it was due to a old battery). Since I bought the battery from a dealer, it was of course registered. Anyhow, I thought those pesky gremlins would go away, but they haven't. I'm still getting all these iDrive malfunctions even after replacing the battery. Just like before replacing the the battery, after turning off the car off and back on, all the malfunctions would disappear and the car would drive normal.
I have a 2004 545.
Would you guys know what else could be the problem?
Please help.
I have a 2004 545.
![Help](https://5series.net/forums/images/smilies/imported/help.gif)
Please help.
Anyone else encounter this problem?
Called the dealer and they said it sounds like definately a low voltage issue, and quoted $1200 for an alternator.
alternator can be rebuilt for around $200 to $300 (replacement of bearings, brushes, voltage regulator). If you live in any metro area, definitely there will be alternator rebuilding places.
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
I have a 2004 545.
Please help.
I have a 2004 545.
Please help.
Before you do that, check if there are no leaks from Valve cover gasket. In my case the oil damaged the alternator.
http://www.partsgeek.com/catalog/200...lternator.html
I went with Valeo (OEM) and it works great!
My Ride: 2008MY 530d Sport, 19" wheels, comfort access, professional navigation, HUD, sunroof, iPod connectivity.
I've been experiencing 'Active Steering Inactive" warnings in my 2008 530D, at varying intervals over the past 12 months. Occasionally, I'd also have to reset the clock and date, and the comfort access operation was intermittent. More recently, a "Heightened Battery Discharge" warning has appeared, and the car was sluggish in starting. Moreover, the CD stacker behind the glovebox reset itself in sympathy - this is the noise some owners have experienced as a sort of clicking coming perhaps from the engine bay. So it all sounded as though my battery was on the way out. Today, I took the car to the dealer to have him check things out. And although we love to hate them, this is where a well equipped, well informed service guy can be worth his weight in, well, batteries! The car electrics were submitted to the full range of tests available via external computer interfacing. Firstly they found that all the auxiliary circuits were functioning normally, and going to sleep properly and repeatedly after "shutdown." The major problem discovered was that my vehicle journeys were too short, and that the battery was simply not being recharged sufficiently between one trip and the next. This was a real surprise to me, as I thought most of my trips were at least 20 km. with occasional shorter and longer ones. Not so. The dealer then recharged the battery, and recommended that I trickle charge the battery overnight about once a month to keep charge levels up. Nothing critical about this either - just a couple of amps at about 14 volts will do, but at the engine bay access point and not at the battery terminals. This avoids upsetting the operation of the intelligent battery sensor fitted to the positive battery terminal. Oh, and all this was done free of charge under warranty.
My Ride: 2004 E60 520i SE 2.2 Auto
socale39
09-05-2023 08:30 AM
