Recommended Tire Pressure
My Ride: 2006 530i Steptronic, Premium Pkg, Cold Weather Pkg, Sport Pkg, Comfort Seats, Navigation, Logic 7, Sapphire Black, Black Leather, Anthracite Trim, IPOD Integration
Produced Sept 5, 2005 CIP 24
I have a 2006 530i and the recommended tire pressure differs depending on speed and load. For me the speed and load differs greatly, and changing tire pressures constantly would be a pain the rear end. Is there any drawbacks to keeping the pressure set at the max which is 36 front and 44 rear. It roughens the ride, but improves the fuel economy, at least I have been told.
Is this true?
Are there any handling drawbacks?
What exactly does the increased pressure do to accomodate higher speeds?
Is this true?
Someone know these answers...common!
Originally Posted by nbarco' date='Oct 4 2005, 02:19 PM
I have a 2006 530i and the recommended tire pressure differs depending on speed and load.? For me the speed and load differs greatly, and changing tire pressures constantly would be a pain the rear end.? Is there any drawbacks to keeping the pressure set at the max which is 36 front and 44 rear.? It roughens the ride, but improves the fuel economy, at least I have been told.
Is this true??
Are there any handling drawbacks??
Is this true??
[snapback]179087[/snapback]
Is this true?
Yes. I settled on 34 rears and 32 fronts to avoid tire wear, promote smooth ride, and to provide good traction.? 44/36 is way excessive on the high side regardless of what the manual or the door says. Others will have somewhat different views, but I am betting that almost no one runs 44/36.
I am not sure. Except for rougher ride, likely excessive tire wear in the centers, and worse traction.?
Less friction if you mean top-end type speeds.
Is this true?
Yes, max pressures ruoghens the ride, but that's about the only drawback. In slow speeds the tire is of course much less flexible but if the suspension is in order this should not be a problem.
And note, it DOESN'T increase tire wear in the centers. This is a old beliving from the '70's when the tires where what they where.
The tyre is under much more pressure whilest driving fast or rough. If the tire pressure is not on max, the tire can "bend under" and even get loose from the rim.
Is this true??
Is this true??
Originally Posted by donv' date='Oct 4 2005, 11:37 AM
[quote name='nbarco' date='Oct 4 2005, 06:19 AM']I have a 2006 530i and the recommended tire pressure differs depending on speed and load.? For me the speed and load differs greatly, and changing tire pressures constantly would be a pain the rear end.? Is there any drawbacks to keeping the pressure set at the max which is 36 front and 44 rear.? It roughens the ride, but improves the fuel economy, at least I have been told.
Is this true??
Is this true??
[snapback]179173[/snapback]
[/quote]Good reads, donv. Other than comfort, higher (within specs of course) seemed to be better from the reading I did. Any reference to center wear seemed to point to "over" inflation, which appears most of us would not do. Did you notice how well the Tire Rack article on tire inflation versus speed tracked with the BMW manual recommendations Das posted. Apparently alot more research in Europe due to the increased speeds that can be driven regularly in there (well at least Germany). I have started going to just under the max recommended pressures, although I run a light load generally. That is what I have done on other car/tire combos with great success, at least on the tire wear side.
Originally Posted by cobradav' date='Oct 4 2005, 12:47 PM
[quote name='donv' date='Oct 4 2005, 11:37 AM'][quote name='nbarco' date='Oct 4 2005, 06:19 AM']I have a 2006 530i and the recommended tire pressure differs depending on speed and load.? For me the speed and load differs greatly, and changing tire pressures constantly would be a pain the rear end.? Is there any drawbacks to keeping the pressure set at the max which is 36 front and 44 rear.? It roughens the ride, but improves the fuel economy, at least I have been told.
Is this true??
Is this true??
[snapback]179245[/snapback]
[/quote]Yes, I did note the correspondence you mention. And, higher definitely is better given very fast driving. The pressures that BMW give exactly mirror the idea from the article that they are aimed at European fast-lane driving. And, I too am not near the maximums for in town driving. But, for the road, I will bring them up some after reading the article. As mentioned, I am at 34 [R] and 32 (F). What are you running exactly? I once put my pressures up to the BMW recommendation and found the ride uncomfortable in general.
Anyone in Germany know the conversion between PSI and bars? I live in Germany and the local Esso station has a digital air pressure filling station that is in bars.
Originally Posted by das' date='Oct 4 2005, 05:13 PM
The owner's manual has everything you need to know:
Attachment 11051
Attachment 11052
Attachment 11053
Attachment 11054
Attachment 11051
Attachment 11052
Attachment 11053
Attachment 11054
[snapback]179135[/snapback]
Site Founders
My Ride: 2021 F93 M8 Competition
Originally Posted by nbarco' date='Oct 4 2005, 02:59 PM
Anyone in Germany know the conversion between PSI and bars?? I live in Germany and the local Esso station has a digital air pressure filling station that is in bars.
1 psi = 0.06895 bar
1 bar = 14.50326 psi
