Recall certain 525 and 530 models (N52 engine)
All owners should request a copy of the Measures Plan and / or Final Report mentioned in note 2 in the SIB. This is a good method to track your PROGMAN (CIP) level. They will use Target data Status and that can be converted to PROGMAN/CIP (Target data Status E060-06-03-515 = CIP 21.01.00 for example).
Originally Posted by cobradav' post='276846' date='May 2 2006, 04:52 AM
Chassis number is the last 7 digits of your VIN. If you do not know your VIN, in teh US the VIN is seen from the looking thru the lower windshield area on drivers side. Not sure in ROW.
Originally Posted by aultimateE60' post='277154' date='May 2 2006, 07:05 PM
even if one's chassis # doesnt fall in that range, would they still in for recall?
Originally Posted by cobradav' post='277196' date='May 2 2006, 09:06 PM
If you do not get letter, then they simply check when u come in for any other reason. It's not a drivability issue.
I got my 2006 530xit (with auto transmission) back from the dealership (in CA) after they applied the service bulletin for the recall.
It seems that it has affected the performance in a negative way:
1.) It feels like I lost 25-35 HP.
2.) There is now virtually no difference between normal drive and sports mode.
3.) When doing a kick-down the car doeas not "pull" anymore like it did before.
Is it just me or did anyone else's performance suffer after the recall for 06E-A01?
Just got my car back from recall service and it's fine--peppy as ever. Only problem is that all the individualized settings are set back to default--triple turn signal (which I don't like), pathway lighting (default is too short), speed signal (I like to be reminded when I'm going over 80), radio presets lost, Bluetooth lost, etc. Half an hour tomorrow and I should be able to fix them. Just minor annoyances. Worth it for a car like this.
My Ride: G30 M550i
Model Year: 2018
http://forums.e60.net/index.php?s=&showtop...ndpost&p=279742
