Rear Wheels have negative camber problems?
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
Like ImSort0fABigDeal said, negative camber is set by BMW for improved handling. If you lower your car... you will need a camber kit to fix the camber in the front, as there is no adjustment for camber in the front. The rears are no problem. I've attached the printout of my alignment specs when I got it done. Hope it helps.
![Rear Wheels have negative camber problems?-alignment.jpg](https://5series.net/forums/attachments/e60-discussion-2/52261d1482364170t-rear-wheels-have-negative-camber-problems-alignment.jpg)
My Ride: 2004 530i
Originally Posted by NeRwEEzy' post='599101' date='Jun 9 2008, 01:49 PM
sorry you cannot rotate with a staggered setup.
EXTERIOR:
LIGHTING:
PERFORMANCE:
The above statement is only true if they are directional tires. Unidirectional and asymmetrical tires are side specific and if installed in the wrong position, the tire will not perform its intended function. However, no damage or premature wear to the tires will result.
My Ride: 2004 530i
My Ride: 2005 545i
Cold Weather Package
Navigation and Logic7 Package
Sport Suspension Package
Attachment 52261
Attachment 52261
