Rear Folding Seat Option - Retrofit?
Old Jan 4, 2007 | 09:06 AM
Redrum's Avatar
My Ride: E60 530d M Sport
Hi
Has anyone had the rear folding seat option fitted after purchase? Can it be done? and I guess it will cost an arm and a leg. I've got an E60 and I stupidly didn't spec this, and as the wife wants me to do all the tip runs - I could do with more space at the back. Secretly hoping the answer is no so i can use her Passat for what its good at.
Cheers
Red
Old Jan 4, 2007 | 09:10 AM
aybeesea's Avatar
Originally Posted by Redrum' post='373585' date='Jan 4 2007, 06:06 PM
Hi
If no-one hasn't had it done it doesn't necessarily mean that it can't be.
It's always worth checking with a dealer in such situations.
ABC
Old Jan 4, 2007 | 09:58 AM
dlevi67's Avatar
I have no direct experience - but reading threads over here and on www.bmwland.co.uk it's basically impossible to do for sensible money. You need to cut sheet metal. You'd be significantly better off by selling and buying another car.
Your wish is (partly) granted.
Old Jan 4, 2007 | 10:10 AM
Redrum's Avatar
Mmm, thought that might be the case - will check with a dealer.
Thanks for the replies guys.
Red
Old Jan 4, 2007 | 11:44 AM
ImolaRedM's Avatar
In most cars I think that is the case, including the E39. But I remember hearing how the E60 chassis was built so that no additional support was needed between the folding seat version vs. the non-folding seat version. They did this as a cost cutting measure that may aid in the retrofit after delivery. But the cost alone of the rear seat back isn't going to be cheap either.
Old Jan 4, 2007 | 11:48 AM
Locksmythe's Avatar
My Ride: Alpine White 2007 550i
I have not taken a very close look at mine, but I do recall that the release levers are actually at the back of the trunk, not close to the seat, so your trunk liner would also have to be modified. I don't know why this is not specced more often in the builds sent to dealer stock. I had to special order for this single option. Of course I loaded up with everything else at that point, too.
Old Jan 7, 2007 | 05:14 PM
thebe's Avatar
I tried. Apparently, it's not possible. I'm in Europe, though.
incoherent
Apr 15, 2015 04:48 PM
Coops
Aug 6, 2003 05:15 PM
RichReg
Jun 20, 2003 06:29 AM
Jun 17, 2003 09:38 PM
