Rear centre console air vents
Dazzpowder? there's a simple solution here, have you got basic or advanced air con, basic only blows fresh air from the rear centre vents.
I have the advanced, the manual says very little other than one wheel is for air flow the other for temperature, nothing about a dependency on the iDrive etc
Maybe its the extra distance from the source of heat to the output that is the issue? Or maybe there is some weird/pointless setting somewhere causing the issue? Like the pointless settings for the centre vents.
It seems this is not a problem, but a "feature". Everybody has this "problem". Check F10 forums, they talk about it as well. Even E39 owners ![Roll Eyes (Sarcastic)](https://5series.net/forums/images/smilies/imported/rolleyes.gif)
Think about it:
- In automatic mode, the warm air always comes from the bottom
- Fresh air comes from the top to keep you fresh
Same goes for rear passengers where also warm air comes out from under the front seats (warming their feet).
But:
- It's still too cold in the back!
- The rotary wheel is pointless.
Once you turn on the manual climate mode, HOT air starts to blow in the rear vents too.
Think about it:
But:
Probation Members
My Ride: BMW 5 series E60
Hi All,
can anyone shed some light on why the rear centre console vents dont blow out warm air? see a hot cold air control and an open shut wheel but I can only ever get cold air to blow out of these vents. Is there a secret in getting them to blow warm air? I own a 2007 E61 if that makes any difference
Thanks
Thanks
![](https://cimg7.ibsrv.net/gimg/5series.net-vbulletin/2000x1504/image_1310b738c84a79a96feea7f0e99eb44fe8362788.jpg)
So here is the answer for rear vent not blowing hot air. I had this issue too but I figured it out now. There’s a control there just make sure you switch from cold to hot air and set it up to the white bar Just like the attached picture.
socale39
09-05-2023 08:30 AM
passtheword1
03-13-2015 03:17 AM
