Rear Camber
Rear Camber
I recently had my car aligned and new tires put on, and I asked my mechanic to dial back the rear camber as much as possible given that the previous rear tires (295 width) had a lot of wear on the inside. He told me he made it as neutral as possible, but they still look like they did before. How can I verify that the camber is all the way it can go? Thanks in advance!
My Ride: 2005 545
My Ride: 2005 545
My Ride: 2006 BMW 550i
My Ride: 2005 545
Think the camber is adjusted with push rod number 7. Also on the next post the toe in and out is adjusted with the essentric bolts 11 and 15
E60 545i REAR AXLE CARRIER
Language: českýdeutschελληνικάenglishUS englishespañolFrançaisitaliano日本語한국어Nederlandspols kiportuguêsрусскийsvenskภาษาไทยTürkçe汉语繁體中文
Sponsored links
RealOEM.com Home => Select another car => Rear Axle => rear axle with suspension
Sponsored links
No.DescriptionSupplementQty From Up To Part NumberPriceNotes Photo01REAR AXLE CARRIER133316770828$1,151.44For vehicles with
Dynamic Drive
S229A=Yes01REAR AXLE CARRIER133316770828$1,151.44only in conjunction with--Blind rivet nut, flat headedM6407146989330$1.2502Rubber Mounting433316770826$76.9103Stopper, front633316765404$38.4304Stopper, top rear233316765409$38.4305Stopper, rear left133316764889$11.4106Stopper, rear right133316764890$7.9207PUSH ROD LEFT133316764887$33.9107PUSH ROD RIGHT133316764888$33.91For vehicles with
Dynamic Drive
S229A=Yes07PUSH ROD RIGHT133316765784$33.9108Hex bolt with washerM14X1,5X138433326760344$5.5009Hex bolt with washerM10X35-Z1-10.9433306760652$0.8810RUBBER MOUNTING front233176767525$18.9311Hex bolt with washerM12X1,5X108ZNS3133306760347$2.5412Hex bolt with washerM12X1,5X87 ZNS3133326760346$2.7513RUBBER MOUNTING rear133176770825$44.3814Hex bolt with washerM14X110-10.9133176760342$3.5015Combination nutM14X1,5-10ZNS3112/200933326760380$2.48For vehicles with
Dynamic Drive
S229A=Yes16Blind rivet nut, flat headedM6407146989330$1.25Ads by RealOEM
Eres un experto usando catálogos de partes para BMW? Queremos ofrecerle una carrera con prospección como representante de servicio al cliente trabajando desde casa. Si usted esta interesado, pulsar acá y envié su currículo
Notes
Sponsored links
Sponsored links
Dynamic Drive
Dynamic Drive
Dynamic Drive
Notes
My Ride: 2005 545
<b>E60 545i REAR AXLE SUPPORT/WHEEL SUSPENSION
Sponsored links
Sponsored links
<div class="scrl" id="div3">No.DescriptionSupplementQty From Up To Part NumberPriceNotes Photo01Wheel carrier, rear left103/200533326770905$590.70only in conjunction with--Wishbone, left103/200533306772241$313.8801Wheel carrier, rear right103/200533326770906$590.70only in conjunction with--Wishbone, right103/200533306772242$313.88<a href="http://www.realoem.com/bmw/showphoto.do?id=33306772242">
Sponsored links
Sponsored links
It should be documented in the paper work. Look at it,, it should be negative 0.8 or 0.9 . the computer wont allow any less camber, So it still will have some but not as radical. what I do is once the rears almost get to the wear bars on the inside half of the tire. Break the rears off the wheels and switch the tires side to side. both insides will now be the outsides. It will double your tire life. I have ventus v12 evo.s with a 280 tread wear , and managed to get 27,400 miles on them. Which is not bad for a soft summer tire. Just make sure that your tires can be rotated side to side. Because some tires are one sided only ( due to different tire pattern on each half ) on top of being one directional..
The Contis are not directional, but asymmetrical so that complicates matters when it comes to rotation. Discount Tire who installed them here in Scottsdale does a lot of exotic cars with staggered tire set ups and the salesman said at least for the primarily dry road driving in the desert that running the asymmetrical tires "inside-out" doesn't affect handling much or hurt the tire. I tried to find info on the web or on tire manufacturer's websites but didn't have any luck. When the time comes to rotate I will give running them inside-out a try and see.
These tires are not meant to be stretched multiple times, but I have heard of people doing just that to avoid the innenr wear. I think I am at -.8 on both rears, but I am confused by "the computer won't allow" for more. Can I have the mechanic override what the computer is telling him? It sure looks like I have clearance for neutral (fenders are rolled), but, admittedly, I don't have a clue what I am talking about. With 295s on the rears, the camber is noticable from behind the car. I can't be eating through $500 worth of tires every 9-12 months. Would a camber kit solve this? I have stock sport suspension. Thanks!
In my opinion, if the camber looks radical the vehicle may have excessive camber. excessive is 2 dg plus. The vehicle can be adjusted to about 1.5 dg and maintain the handling performance that BMW intended.
The information should have been on the adjustment printout sheet. The most sophisticated alignment system I know of is at the certified BMW dealer. Cost, barring replacement parts should be about $250.00
