Rear brake pads service error
My Ride: E60 525i M Sport
Hey guys, I had replaced my Angel eye globe in my e60 and I had parking light failures appear because of the led. I think I found a solutiokn for that however in the process of trying to reset the errors on that I had accidently reset my brake pad indicator on my cluster. Anyways I read up on forums how to reset it again however every time I have it reset it clears and then goes back to -25000 again.i can't manage to keep it cleared
Engine: 3.0 B58; 3.0 M54
I think you have to replace pad sensor with a new one. Once you reset it, it see it is an old sensor then gives you the -25k. There is also a way to delete the sensor all together but you have to look that process up.
Engine: N54
The pad thickness can be measured then entered into the brake service monitor to reset it.
You will need to plug into the OBD port with a capable scanner such as Foxwell.
For example, if you measure and enter 7mm thickness, the miles will reset to an approximate distance.
Engine: N54
Don't know about INPA, I haven't used that much
But I have done it a couple times for various reasons with the Foxwell and it works well.
Cal@Jlevi SW
Archived Sales
May 3, 2010 02:29 PM
acribb
Oct 5, 2009 06:48 PM
the-oneil
Jan 6, 2008 05:36 AM
