Rattles & Squeeks
Old 12-18-2007, 11:47 AM
Leburpor's Avatar
My service guys had told me that rattles and squeaks are covered in the first year and it's a goodwill decision by the dealership thereafter. I've never checked out the documentation to determine if this true or not, as they've always tried to fix the problems for me at no charge.
I've learnt that if I pin point the source of the problem to them, they will then find a fix for it. If I tell them there's a rattle 'somewhere over xxx', the the likelihood for a long term fix is low.
Having said that, they haven't been able to fix my rear shelf problem entirely. When it was making 'popping' sounds on the right, they fixed it, then the left start to make noise. When they fixed the left, the right became noisy again. In the end I just jammed a black soft cloth between the shelf and rear seat. Now my car is quiet
Old 12-19-2007, 02:16 PM
Russ1974's Avatar
Originally Posted by BOBUCRUZ' post='508207' date='Dec 18 2007, 02:41 PM
Thanks for pointing this our Russ. I will follow up with the dealer on that today. Did you put some leather stuff on the seats, or did the dealer. If so, did the dealer charge you or cover it under warranty? Thanks.
I'm in the UK. Here, the dealer is excellent. ANYTHING I take it in for, any problem at all, it's covered, even things which are just bugging me a little. They applied the "leather stuff" and did not charge.
Old 12-19-2007, 05:29 PM
BOBUCRUZ's Avatar
My Ride: 2004 Black BMW 525i
Imagine that, anything is covered.
Old 12-19-2007, 10:46 PM
BMDiesel's Avatar
Location: Europe, Netherlands, Near the (German) Autobahn
My Ride: 525d E60
I don't have leather but my rear shelf does creak (when cold outside)
Old 12-20-2007, 04:05 AM
stavros's Avatar
My Ride: 2004 BMW 545i, M-Sport Bodykit, Sports Suspension, Sports Seats, Active Steering.
My 2004 545i, only 29,000 kms and the doors creak on their rubber seals but subdued when stereo is on low volume. Otherwise, faultless and a dream to drive.
Old 12-20-2007, 10:35 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Same here when it?s below 0 celsius degrees, but...
At first I thought it was the rear shelf creaking, but I found out it's the seals of the container hood that make the sqeaking sound. I put some CRC's silicone there and it stopped that awful sound which came inside so loud. I know the silicone will tear off in time but it's ok because it is so easy to apply again. It's been a month now and the seal is still covered in a very thick layer of that stuff.
Old 12-20-2007, 11:09 AM
BMDiesel's Avatar
My Ride: 525d E60
by container hood you mean trunk or boot lid right? Try talcum powder next time, that smooths without getting sticky and/or dirty and thus sticky over time. Also works great for door seals against freezing stuck. (use a towel to cover interior while applying, or do this first and then vacuum the interior)
I hardly dare to touch the car (it's so dirty the alloy wheels look like they were shiny black painted) as we have slightly freezing weather and the roads are a mess.
In fact, I have to clean the headlights almost every trip as they get so dirty they don't emit enough light any more.
Stupid to see the washers cover in the bumper but that apparently was an option on this car so no washers up front.
Old 12-20-2007, 11:13 AM
Anzafin's Avatar
Thanks for the tip! And yes, I mean trunk lid
Old 01-09-2008, 08:36 PM
Gene's Avatar
my car is about 2 weeks old and I have started to notice I get a creek/rattle sound when I hit a bump. It's coming from the back seat, I am thinking it's the leather back hitting the storage shelf also...I will call my dealer tomorrow and see if i can set-up an appointment for them to check it out, I will post a follow up after...
James McCullough
07-31-2016 02:46 PM
aNo94
08-22-2015 06:48 AM
PelicanParts.com
08-10-2015 01:55 PM
srogers535x
08-05-2015 08:48 AM
Kbc
07-27-2015 05:51 PM
Quick Reply: Rattles & Squeeks
