Rattle noise at dashboard
My Ride: e60 520d LCI
I have a rattle noise when engine rev was low can you suggest me what i should be check first ?
-I already tighten bolt that attach with stabilizer brace
Motor mount? It can be tough chasing a noise propagating through a metal structure (body shell) as the sound travels much faster than in air, so your brain can't use its normal algorithm to determine the direction. I'd suggest getting a mechanic's stethoscope (well under $10 for the adequate one from Harbor Freight) and poke around and see if you can find the "hot spot"...
