Rain Sensor Plug Help
First of all, Hello to Everyone on this forum.. Im a recent acquiree of a 2006 525d in need of some TLC.
For some reason, (which im sure i will find out soon), the rain sensing wiper plug has been cut offso im left with some bare wires...
I have managed to find a connector that will work, but dont have a clue which wire goes where..
Can any one help / provide a pin out layout... Its 4 wires... the connector has pin numbers 1 to 4 so i should be able to match any info against these... I know i have a yellow wire and a black wire, cant remember what the other 2 are.
Thanks a lot in advance
Red/Green - is power 12V
Brown - Ground
Yellow - K CAN Low
Black - K CAN High
Brown - Ground
Yellow - K CAN Low
Black - K CAN High
Brown - Ground
Yellow - K CAN Low
Black - K CAN High
Thanks loads for your help.......
Do you know which one goes to which pin??
Red/Green - is power 12V - Pin 1
Brown - Ground - Pin 2
Yellow - K CAN Low - Pin 4
Black - K CAN High - Pin 3
Originally Posted by or_550i' post='930964' date='Jul 2 2009, 09:38 PM
That would have been helpful wouldn't it...
Thanks a lot... top help...
Ill see how it goes!
Just wanted to give a shout out to or_550i for the pin position and wire colors. Just rescued an e61 from an owner who was NOT a competent DIY'er. Had the wires ALL mixed up. Hopefully that will give me the RLS back!
twh (06-17-2024)
