Radio cuts out,radar detector sees swing in volts
I recently have had the problem with my radio cutting out. I had a radar detector installed in the summer but recently it has been beeping (one beep) and/or displaying "hi volts" and "low volts" in its display. Both happens when I shift. I had the guy that installed the detector look at the radar connection, he said it was fine but moved it from the fuse box under the steering column to the cigarette lighter on the passenger side. Same thing happens.
He did notice that if you sit idling and rev the motor the courtesy lights below the door fluctuate in brightness and the detector beeps.
Anyone have any experience or opinions with this?
No problems here, pennetta. I am hardwired into the yellow green 12V switched wire going into the rain sensor. Maybe you have a serious short somewhere in your system.
