Radiator fan at maximum speed when i turn on the car
My Ride: 2009 BMW 528i
![Lightbulb](https://5series.net/forums/images/icons/icon3.gif)
Hey there, i have a 2009 528i, so, 3 months ago i had an accident, my bad because i didn't have insurance at the time, so i spend all my time repairing my car which was a succesful.
The thing is that my friend once time ago tried to jump my car and i didn't realize he put the wires backwards, so, it burned my alternator and ABS module, i changed both of them, and soon i'll reset ABS lights.
But now i wanna know something about the title, if its normal to that happens, i also changed the thermostat because the old one got broken on the accident, so i installed the new, no leaks fortunatelly, and check the water pump which is also good because i heard it pumping the coolant, so any ideas?
Checking the KTMP-MOM before bleeding and before realized the coolant level sensor was disconnected by me always like 80-90 degress on a normal drive arround my hood, after bleeding and putting back the sensor the start temps are between 45-55 degress (in celsius well), i drove a short distance and rev up the engine, it didn't surpass 75 degress, is that normal?
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
The fan at max speed is not normal. Need to read the codes to see what part is causing it. If you don't have a BMW specific reader you'll need it to troubleshoot this issue
Update, I found there was 2 fuses from the fan missing, but when my friend put the cables backwards I took a photo of all the fuses and I realize there wasn't there at the time and I'm sure at these time the fan wasn't loud, but yup, if there's any I can help once I solve that I'll let y'all know!
twh (Yesterday)
e60rider
05-07-2014 05:20 PM
Isaiah_Charles
05-14-2012 02:06 PM
