Raced an Audi S4 4.2
We both started from a light. Both we pretty equal in acceleration- When he shifted, I pulled ahead- When I shifted, he pulled ahead. But as we went through the gears I gained more when he shifted, because his took longer- and he gained less when I shifted, because of my faster SMG shifts. After we got into fourth gear I was clearly ahead, but not by much. If I was shifting a traditional stick, I would not have had any advantage.
This is the 2006 S4 4.2L V8 340HP? WOW really?? Isnt it lighter... and has more HP. COOL!!!!!!!!! So we can beat if if not still keep up if its a bad driver!
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
My Ride: 2015 535D M Sport
I think an S4 4.2 is a pretty good match for a 545. The 0-60 MPH numbers I see are in the same range, some as low as 5 sec. Shifting speed could be the differentiator.
My Ride: 09 E90 M3
Originally Posted by EBMCS03' post='230729' date='Jan 27 2006, 08:13 PM
This is the 2006 S4 4.2L V8 340HP? WOW really?? Isnt it lighter... and has more HP. COOL!!!!!!!!! So we can beat if if not still keep up if its a bad driver! ![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
[/quote]
You're right! I just looked... 3900lbs for the auto and 3800ish lbs for the manual! WOW HEAVY!
![Embarrassment](https://5series.net/forums/images/smilies/imported/ohmy.gif)
Originally Posted by alpineweiss' post='230753' date='Jan 27 2006, 06:08 PM
[quote name='EBMCS03' post='230729' date='Jan 27 2006, 08:13 PM']
This is the 2006 S4 4.2L V8 340HP? WOW really?? Isnt it lighter... and has more HP. COOL!!!!!!!!! So we can beat if if not still keep up if its a bad driver!![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
[/quote]
Well, the 545i Steptronic is 3,814 curb-weight stripped. That's not so different that I'd be inclined to think of the Audi as a pig, but not the 545i. And, I think the manual 545i is 3,803.
My Ride: '06 550i 6 Speed MT, Navigation, PDC, Cold Weather Pkg, Logic7, Prem Pkg, Sport Pkg, Active Steering, Comfort Seats, Comfort Access, HUD, Alpine White on Black Dakota & a Big Grin ;-) <---- On the vessel from Germany...
'05 545i 6 Speed MT, Navigation, PDC, Cold Weather Pkg, Logic7, Prem Pkg, Sport Pkg, UUC EVOIII SSK, Silver Gray on Black Dakota..... (Buy back by BMW NA)
My partner has a 2006 A6 4.2, he got it about 3 months after I took delivery on my 545i and frankly - you can't compare the two... the Audi feels havier and slower, even slower in acceleration then my 2001 A6 2.7T, I've never raced him, but the Audi is definitely slower.
here's the specs from Audi's website... I was sure I was right so I had to check myself...
A6 4.2 Specifications
Model Configuration
335 hp with 6-speed Tiptronic transmission and quattro all-wheel drive
Engine
DOHC aluminum 90-degree 4.2 V8 with 5 valves per cylinder, variable intake valve timing and intake manifold
Displacement: 254.04 cu. in.
Bore: 3.33 in.
Stroke: 3.65 in.
Compression ratio: 11.0:1
Horsepower: 335 hp @ 6500 rpm
Torque: 310 lb-ft @ 3500 rpm
Performance
0-60 mph in seconds: 6.0
Top track speed: 130 mph*
EPA fuel economy estimates (city/highway)*: 17/23 mpg
Chassis/Technical
Fully galvanized steel unibody with multi-step anti-corrosion protection
Front suspension: 4-link with upper and lower control arms, stabilizer bar and separate coil springs/shock absorbers (gas-charged)
Rear suspension: Fully independent trapezoidal-link with stabilizer bar and separate coil springs/shock absorbers (gas-charged)
Electronic Stabilization Program (ESP? 8.0)
Servotronic? vehicle speed-sensitive power steering; turning circle: 39 ft.
Curb weight (lbs): 4145
Capacities:
Engine oil (qts.): 9.3
Fuel tank (gallons): 21.1
Model Configuration
Engine
Bore: 3.33 in.
Stroke: 3.65 in.
Performance
Chassis/Technical
Capacities:
My Ride: MY RIDE is DA real .-) HAMANN 5 aka BLACK MAMBA born on 16/06/2005/delivered on 05/08/2005 as following:
530dA (steptronic), Black II (JET), leather Dakota auburn black, mapple trim, head-up display, dynamic drive, active steering, adaptive xenon headlights (auto levelling) with headlight washers, alarm, comfort seats with massage function, advanced A/C, big compartment armrest, aux-in, MP3, Logic 7, Radio PRO, CD in-dash+cd changer, power rear sunshades, rear airbags, park distance control, auto dimming folding mirrors, smoking package, shiny shadow line (individual), fold down rear seats, ski bag, sport suspension, run flats on �116-style� rims (Good Year NCT5+), cup holders, debadged, fire extinguishers, additional permanent power outlet, BMW coat hanger, trunk release button (installed by Hobi), GPS tracking device and a big thx 2 Iceman.
Mods done:
� Authentic HAMANN FRONT APRON Including ellipsoid fog lights Item-No.: 10 060 110
� Authentic HAMANN REAR SPOILER Item-No.: 10 060 130,
� Authentic HAMANN HAMANN ALUMINIUM PEDALS For cars with manual gearbox Item-No.: 80 099 100 81,00 For cars with automatic transmission Item-No.: 80 099 120
� Authentic HAMANN FOOT REST In aluminium For left-hand drive vehicles Item No. : 80 099 122
� Authentic HAMANN HAND-BRAKE LEVER In aluminium For left- and right-hand drive cars Item No. : 80 099 216
� Authentic HAMANN Idrive of alu (sorry this is the only one in the World) but you can have it in carbon fiber ,
� Authentic HAMANN EXCLUSIVE FLOORMAT SET In black with HAMANN logo in silver For left-hand drive cars Item-No. : 80 060 120 For right-hand drive cars Item-No. : 80 060
� Authentic HAMANN COVER FOR OIL FILLER CAP In aluminium Item-No.: 80 099 117
� Authentic HAMANN SPORT REAR MUFFLER 4 TAILPIPES Sport rear muffler with four round stainless-steel tailpipes ( � 76mm ) Item-No.: 50 060 111
� Authentic HAMANN new add-on for M pack rear with diffusor for quad pipes -AVAILABLE NOW (http://forums.e60.net/index.php?act=ST&f=22&t=30630&st=0#entry332409)
� ///M steering wheel w Pegasus logo (this will be also changed to three spoke sports)
� ///M pack rear
� HAMANN ECU upgrade 265 HP 608 Nm.
most improtant:
�real and working like a charm forumsbuy real LED tails and PIAA 4700k fogs!!! for HAMANN full front apron you need H3
� CustomAngels, Angel Eyes Brighter than stocks 10X, WHITE & (REd for shows).
� Authentic HAMANN LIGHT-ALLOY WHEELS DESIGN EDITION RACE 20"
Ultra-light forged 3-pieced light-alloy wheel, Cross-spoke-design,Spider in black, titanium, screwing,polished flange
DIMENSIONS : 9.0 J x 20 FA Item No.: 91 207 315
10.5 J x 20 only RA Item No.: 91 207 625
Recommended 20" Complete Wheel Set DESIGN EDITION RACE I went with most aggressive Combination A.10 FA 9.0 J x 20 / RA 10.5 J x 20 with tires: FA 245/30 ZR 20 / RA 285/25 ZR 20
� Authentic HAMANN LOWERING KIT 4 progressive sport springs Lowering by approx. 40 mm FA, 20 mm RA Item-No.: 20 060 125
� Authentic HAMANN TIRE - PRESSURE CHECK SENSOR SYSTEM
� Authentic HAMANN SIDE SILLS Item-No.: 10 060 120
� Authentic HAMANN REAL CF ROOF SPOLIER Item-No.: 10 060 235
� Authentic HAMANN AIRBAG SPORT STEERING WHEEL 3-SPOKE Three-spoke design w their SMG paddles (For assembly O.E. airbag in exchange)
� Authentic HAMANN sports mirrors (all functions)
!!!!!!!!!!!!!!!!!!! and of course !!!!!!!!!!!!!!!!!
E60.net Clings
Still to do list;-):
� Our Hobi's camera system from : ww.switchchange.com).
� Individual leather interior (auburn+auburn alcantara)... and drive with sheer drivin' pleasure ... until 2009/2010 F10 comes or E60 possibly a 540d V8 diesel early in 2009 badly juiced!
guys Audi is no match for anykind of E60??
kapichi?
![Devil](https://5series.net/forums/images/smilies/imported/devil.gif)
