Quick NCS question for anyone with a manual trans
Vkhong, You'be been very helpful so far. I don't think I am being too clear and I am sorry it's been a long day..... how about you do me a favor and read CAS and KOMBI traces, that will help me more than likely. You seem to have the SAME vehicle M54 6 speed. perfect!
Does anyone know if what I said is correct? If I write the original FA back will it code all modules with original settings...in a sense reverting back to what I did? Sorry it's been a while since I messed around. Which modules would I write to when writing the FA back? I assume I would do this in Expertmode right?
S207A 6-speed manual transmission - Basically if i wrote to KOMBI (i believe it automaticlly select CAS module too) what would this option be in the trace file. I can just change that and I assume the gear error would go away. I've had this problem in the past in an E46 when I put in an AUTO's cluster in a Manual car. The cluster doesn't communicate because there's no manual tranmission.
chadillac2000
42
09-13-2017 11:15 AM
