Quick NCS question for anyone with a manual trans
If you have your trace file can you please give me the code/option for transmission? I coded two E60's today and I did not clear the FSW_PSW.MAN file. One was auto and one was manual. I think I coded the manual with the auto's .MAN file. I saved the trace file for KOMBI but I don't think I moved the FSW_PSW.trace to my temp folder. A tranny error popped up later and i figured it would clear but just in case. The only thing I did was code KOMBI
Sorry if this is not in the right place but I don't remember a coding forum here.
Achtung
Achtung
Achtung
Achtung
German and BMW language is a bit rusty......
K8116_KLAPPENAUTOMATIK
flt_gesperrt
or
- K8116 KLAPPENAUTOMATIK
- fkt_gesperrt
- K8119 PRG AUTOMATIK
- par_gesperrt
Model Year: 2010
The option "K8116_KLAPPENAUTOMATIK" is in the CAPPL module. You mentioned you coded the KOMBI module.
You want the trace for the CAPPL module?
Model Year: 2010
The function "K8116_KLAPPENAUTOMATIK" is in my E60 CAPPL / CCC_APP.C04 module. I have the 6-speed manual transmission.
HTML Code:
Generated with NCS Dummy version 0.4.0.0 beta 2 ? copyright (c) 2010 revtor software Output : Trace Functions Chassis : E60 Module : CCC_APP.C04 Trace file : "C:\NCSEXPER\WORK\E60_CAPPL_FSW_PSW.TRC" (FSW/PSW) U S FUNCTION KEYWORD FUNCTION KEYWORD TRANSLATION PARAMETER KEYWORD PARAMETER KEYWORD TRANSLATION K8116_KLAPPENAUTOMATIK fkt_frei function free * fkt_gesperrt function locked K8119_PRG_AUTOMATIK par_frei parameter free * par_gesperrt parameter locked
Ok what happened is that I did not clear the FSW_PSW.MAN and the vehicles are very similar, just one is auto and one is not. It's been a while since I coded and it was stupid not to save the trace file. So I do not have the trace file. So I wrote the wrond FSW_PSW.MAN to the other car and only coded KOMBI. Now there is a Red gear symbol and I know exactly what happened! It's difficult to sort through lines of code and so forth.
The only thing I did was select KOMBI to code. I remember it selects other modules as well such as CAS. But yes a trace would be perfect dude. The KOMBI I want to compare and perhaps there is a tranny option. The vehicle order is....
E60_#0904&LCSW%0354*NA53$217$226$229$300$302$319$3 39$354$403$430$431$435$441$442$459$473$481$488$522 $524$534$540$563$589$605$639$645$655$676$694$697$7 85$818$823$845$850$853$876$925$992-B110+K633+NAUX
If worse comes to worse I am assuming that I can write the original VO back to the modules and it will code it according to the default. Correct? From there I would be able to get the original FSW_PSW.MAN file and save it and then recode options. I am assuming. I've been working with other tools besides NCS but I think I'll go back to NCS because of the ease of use. Can you send me your original FSW trace file so I can compare? I do not use the NCS dummy, never have...should probably learn. But which option is the one you have? free or locked? I thought those may be for the tranny but I'm unsure. A FSW trace would be ideal or some input on how to disable that gear message and dong.
So does anyone know what KLAPPENAUTOMATIK means? Or rather which option is for the
Model Year: 2010
On my 6-speed manual vehicle, the CAPPL module has the following functions and parameters. They were marked with an asterisk in my earlier post.
HTML Code:
K8116_KLAPPENAUTOMATIK fkt_gesperrt K8119_PRG_AUTOMATIK par_gesperrt
Model Year: 2010
HTML Code:
E60_ E60 chassis #0904 Start build Sep 2004 (the build date is a later, completion date) &LCSW Dakota leather seat trim, schwarz / black %0354 Exterior paint Titansilber Titanium Silver Metallic Silver *NA53 525i, 4D Sedan, 2.5L 6Cyl, US/Canada $217 S217A Leather steering wheel $226 S226A Sports suspension settings $229 S229A Dynamic Drive etc
I think forum member Bruce Miranda has a list of BMW options as well.
HTML Code:
-B110 Battery, non-AGM, 110 Ah +K633 Bluetooth retrofit +NAUX Aux input retrofit
